connecting a bosch 3237 to a fein turbo II
andre mallegol
>I am trying to connect a Bosch 3727 sander (discharge od 28mm) to a Fein Turbo II (inlet od 35mm). Tried Woodworker Supply, Rockler as well as Bosch and Fein, no luck. Anyone done this? Thanks for your help.
Re: connecting a bosch 3237 to a fein turbo II
Grant in Iowa
>The Fein regional rep gave me a semi-trasparent silicone sleeve that goes inside the end of the tube on the Fein, and over the outlet on the sander. It is a bit tricky to get in place the first time, but works great as an adapter. It even stays "stuck" in the end of the vac hose when I do regular cleanup with it.
In my case, this adapted the Fein vac to my PC sander.
THis is NOT the black/gray multi step adapter that is often bundled with the Fein accessories.
She gave it to me for free when I bought my vacuum at a local tool supplier demo days sale.
I vaguely recall her saying that it wasn't a commonly marketed accessory, but that she had a bunch of them that she gave away to new owners, since many of the new sanders require this to connect properly.
I looked online and didn't see it anywhere just now. It is a semi-clear tube of what appears to be silicone and is about 1 1/4" long.
Good luck in your search,
Grant in Iowa
Larry in NW Ohio
>This is really a pet pee for me. Can`t the tool manufacturers get together and make htese vac hoses and outlets on sanders other dust making machines the same. They all seem to be just a little under or just alittle over one or the other. I think it`s just plain stupid. There isn`t any reason why they can`t be the same. Larry
andre mallegol
>Thanks Grant, I hope I can find a Fein regional rep.
Andre
Ed Mulligan, Cape Cod
>My Festool vac hose fits many of my non-Festool portable power tools. I don't know if it will work with your Bosch sander. Perhaps someone else will speak to that.
Re: connecting a bosch 3237 to a fein turbo II *LINK*
LGuthrie - Merrill, Wi
>Do you have the Bosch hose adaptor, Bosch #RS006 ? The o-ring on the round end makes up the difference in diameters and holds the hose on securely. I have a 3725 (same sander, 5" pad) with adaptor connected to a Turbo II.
Bosch Hose Adaptor
andre mallegol
>I do have the RS006 Vacuum Adaptor. No O ring in the package. I'll check at Ace and see if I can find an O ring that fits. Thanks for the lead.
Andre
