OT sorta, Kneepads?
OT sorta, Kneepads?
OT sorta, Kneepads?
Gary Camp, Bend, oregon
>I have a lot of work to do under my house. Things have moved nad shifted, creaked groaned and settled, since they put the house back on a foundation a year ago. Call backs to fix those kinds of things were not part of the deal, money you know, plus I am sure that I will be a LOT fussier than any contractor that I can afford. Not to mention the fact that I am about the only person I can afford right now. I have a set of hard shell kneepads that I use at work when I lay carpet squares or other low work. They don't seem cut the mustard for my boney old knees for long periods in dirty, rocky condtions. Anybody have any recomendations for GOOD kneepads? I need to get pair for Lisa and I. I just can't wrestle 16' green Doug Fir 4X8's under a house like I usta could ;-( Aren't I a nice guy I'm gonna get Lisa her own kneepads and it isn't even her birthday.
glc
glc
Re: OT sorta, Kneepads?
Army surplus
GolfSteve in Calgary
>Go to an army surplus store, or that sells military and police type stuff.
I bought a pair of army surplus knee pads that are the best I've ever used. Soft on the inside, hard shell on the outside, they fit well when kneeling and are comfortable to walk in. $30 bucks used; $45 new.
The ones I bought look like these: http://www.militaryclothingoutlet.com/PhotoGallery.asp?ProductCode=209%2D100
The only downside is that since there are lots of straps and velcro, the things are a pain to take off when you're running to the hardware store for the twelfth time to pick up that one bolt you need. Given the way I dress when working around the house, if I walked into the hardware store wearing cammo knee pads, someone might call the police.
david schaefer fairbanks ak
>I've been looking at the pads from Lee Valley. Other than the price these seem to be the ticket for someone who spends a lot of time on their knees. Next time I have a floor project I'll have a pair.
GalenV in Iowa
>I don't use knee pads as to me they are hard to crawl with.
Not bad if you are just in one spot and up and down.
What ever you get also get a couple of those foam garden pads that you can get in several sizes. They sure come in handy when you want more padding under your knees or for an elbow or hip on your side or your head and shoulders if on your back.
Galen
Kneeling pad?
>I find kneepads awkward when I'm working in dirt - seems like a rock always winds up between pad and knee. I use foam pads. In my case, I have some foam that came with some computer or other at work, but you can get kneeling pads in the garden section of about any store with a decent garden section. If one's not enough, glue two together.
It's true that you need to pick them up and move them each time, but it's a lot easier to shake the stones off as you move.
Good luck - working under a house is no fun regardless.
Off the original topic suggestion: if you've got the clearance under the house, consider buying one of those plastic trays that the home centers sell (often also in the garden department), about two feet long, 18" wide, 6" deep, to hold tools and stuff. They're rounded on each end to make it easy to grunt them around, and it's great to have somewhere to put stuff besides the dirt - easier to find the tools there than in the dirt, too (having spent half an hour looking for the tin snips my partner left under the house after one project, I'm VERY aware of that part).
Re: Kneeling pad?
Bill White
>I bought a pair from Lowe's about 7 yrs. ago. Grey with a high density pad inside. Sort of an accordion look. Crossing stretch straps. Very comfortable and logn wearing. Couldn't find a brand on 'em.
Bill
Re: Kneeling pad?
>Man I can sure realte to looking for tools, I spent a long time last week looking for something that turned out to be under me. I tyr to use a couple of buckets but digging around in a bucket for for something anit much fun either. I'm not sure a pad would work as I am moving around a LOT and of course the place I am working is 45 feet from the entry hatch. Lisa can stand up, bend over at the waist and walk, I am a couple of inches to long in the legs to get away with that so for me it crawl or try to "nuckle walk"
glc
Re: OT thanks for the responses
>I guess I will have to go into town this afternoon and do some shopping. We do have a small surplus place, I didn't tink to look there.
glc
The good news...
>When I briefly did sheet metal work, we did a couple of retrofits (heaters and such) on houses with code minimum crawl spaces. Let's just say it was a good thing I was younger - after wiggling like a snake back and forth all day to get into the space, I was just a leetle tired.
Roller blading pads
Tom Dunlap
>A number of years ago I bought a pair of Rollerblade kneepads with hard caps for the knees. I eventually removed the hard caps and found that they articulated very nicely and still gave good protection.
Gel-filled Patella pads
Kneale Brownson Thru skiing in CO till fall
>I've had tender knees ever since I had both aspirated in 1973 to reduce swelling from skiing too many bumps.
I've had a bunch of different hard and soft-shelled knee pads over the years, none of which worked satisfactorily for extended periods of use.
Several years ago I spend twice what I'd ever spent on knee pads before to get some of those gel-filled knee pads with the extra-long velcro straps. They stay in place much longer than the earlier models and provide comfort for half-days at a time spent on my knees (flooring and roofing type projects, as well as plumbing and car repairs). I've used them so much the "Patella-T" brand cast into the rubber exterior pads are almost worn off.
Regarding Bill's tray suggestion: I usually take tools in a shallow plastic pan when I'm going into a crawl space with no floor.
With my knees, just the thought of kneeling......
Art Silva
>HURTS LIKE HELL!
Re: Gel-filled Patella pads
Larry in NW Ohio
>Gary I tried many different kinds of knee pads, most of them felt good on the knee but in back of the knee where the strap goes is where I had a problem. Then I ran into a place that made a pants with a knee pocket to put a cushion in for the knee, best thing I ever bought. You have no straps and the pad doesn`t move around and slip. You can go to www.skillers.com and get the information or go to ebay and look them up there. Larry
AMEN!
Dave Anderson (PacNW)
Re: Kneeling pad alternative
GalenV in Iowa
>Since the labor is "cheap" start at the entrance and dig a trench deep enough you can stand up. :>)
May come in handy when you got to do that plumbing repair down the road. :>(
I cannot say it too often but a bad heart does get me out of doing tough jobs like yours.
Trouble is it prevents me from doing many fun things too.
Galen
Well, my own labor...
>isn't that cheap. Besides, the best thing I grow at my place is LAVA ROCK. They hauled 16 truck loads away from the house and shop site, they left probably 4 more. I think I will make do with 3-1/2 feet.
glc
