Looking for a small plunge router
Jesse Cloud
>Hi all,
Lately I have come across a few applications where a small plunge router would be very handy. I would want it to accept porter cable style guide bushings.
Anyone have one or know of such a beast?
Thanks in advance,
Jess
Re: Looking for a small plunge router
Check out MicroFence *LINK*
>Here's the top-of-the-line entry in this category. Give them a call and see what they can do for you.
Ellis Walentine, Host
MicroFence Plunge Base
Robin Corell in Atascadero CA
>proxxon also makes a mini plunge router in the $100 price range, but it takes the dremel size router bits and I don't think it takes standard template bushings. The tool store near me just started carrying the whole proxxon line and it is a solid little unit.
Robin
Re: Check out MicroFence
Scott in Montana
>I have the MicroFence plunge base fitted on a Porter Cable 310 router and love it. Took me a while to accept the initial purchase price, but now I couldn't live without this tool.
I use a 1/4" collet and also have an Amana 1/4" to 1/8" adapter bushing for using the smaller cutters.
BTW Sadly the 310 is discontinued but there still seems to be adequate inventory around the country.
Scott in Montana
Joseph Mulherin, Sr
>Jesse, while not a plunge router, try going to the Buffalo Tools website and you will find a small trimmer router used for trimming, etc. Mine uses the 1/4" collets and has a 1/8" collet adapter.
SN#20054FW
Bill White
>I have a small 1/4" Makita that's a sweety. PM me if you're wantin' the model. I'm not even sure if it is still being made.
Bill
Jim Dillon
>Scott,
Thanks for that firsthand info. I handled a Microfence plunge router attachment at a woodworking show and was very impressed. The rep was using a Bosch Colt, but said they have one for the PC-310 which I have and love. While not inexpensive, one is buying a quality tool. Maybe next Xmas... .
Jim
Plunge Router or Plunge Base
Howard In Toronto
>If you're looking for an actual plunge router, I've got this unit:
http://makita.ca/index.php?event=tool&id=98&catid=33
and it does absolutely everything I could ask of it.
It's got plenty of power and is extremely accurate.
As long as 1/4" shaft bits don't limit your needs, it's a very solid performer.
If you've got a laminate trimmer and are interested in using it, Ellis's recommendation is probably the best in the marketplace.
But if you want to use a Dremel unit or P-C 310, check out this fellow's work:
http://www.bishopcochran.com/
It's like a little jewel.
HTH
Howard
>The plunge base plus edge guide looks like just the ticket.
I don't have enough routers. [g] Can you recommend a favorite router to use with the plunge base?
Re: Plunge Router or Plunge Base
Jesse Cloud
>Thanks Howard. That looks very interesting. Can you put Porter Cable bushings (template guides) in it. I hate accumulating a set of guides for each different router I have.
jerry mayfield
>Am I the only one that thinks $400.00 is insanity ?.
Jerry
Depends
Dan Donaldson
>For anything like this that is not mass produced, it is going to be expensive to get quality. If you really have a need for it, then the initial price is probably not the deciding factor. If not, then it is basically insane (for your application). Tooling up for something like this is not inexpensive and you have to recoup your investment over however many you figure that you can sell. For millions, not so much per unit, for thousands or less, that can be quite a hit.
JerryBurns
>Jeese I just set and used my micro fence I put a bosch colt in it.
a bit pricy but well worth it I use routers a lot router # 6
James LaMuraglia
>First of all, I work for Trend Routing Technology. Trend manufactures a 1-1/4 horsepower, variable speed plunge router. It is reasonably priced and it is rated for light construction and DIY work.
Re: Looking for a small plunge router *LINK*
karin corbin
>There is a precision router base for a Dremel Motor, it accepts Porter Cable bushings. The maker is Bishop Cochron.
You can plunge it into work but not with spring return.
Template Guide Base
Larry_In_Lima
>Stewart MacDonald makes a very nice solid metal one. I've got it, used it once so far, very nice. Larry
