How to make the most of a small table saw?
Michael Bush
>I tried to post this earlier, but maybe it got caught as spam?:
Someone needs to loan David Yoho some heart medicine, because he is going to have a heart attack when he learns I bought a table saw.
I got an offer I couldn't refuse. It isn't a great saw by any means, just a little Ryobi contractor's saw, but brand new with a stand for $84, I figured it might speed up something I do.
As David knows, I am to say the least hand-tool intensive in my woodworking. Production speed means next to nothing to me. I had two years of woodworking shop in Jr. High and High School, but nothing captured my imagination like the Hay cabinet maker's shop at Colonial Williamsburg. I have a few C18 tools and many from the C19, and many more patterned after those older tools, and hand work, even to the point of squaring boards out of split logs, has been the heart of my woodworking. I don't have to make a living at it. I don't have to do anything but enjoy myself and be pleased with my results, and I have found this approach to be enjoyable and pleasing.
So now I have this little table saw, not my first power tool by any means, but still a big step for me. It joins a Delta 14" band saw and a little lunchbox planer, along with some drills and such in my small power-tool arsenal.
The question is, what do I need to do to maximize the performance of this small saw? Thin kerf blade? I've read about those and have mostly decided to do it. A better fence? If so, which one? What other suggestions do you all have?
(And don't forget David's heart medicine!)
Re: How to make the most of a small table saw?
Dan Donaldson
>I would say that it depends a lot on what you plan to do with it and how much money you want to spend. A thin kerf blade is probably not a bad idea, along with some kind of an outfeed table or some such. I would think about making a sled for cutting smaller parts and unless you plan to do a lot of ripping to different widths, I would just use the sled and the current fence. It may be a bit of trouble to set up, but as long as you can lock it down, it should work for you. I am saying this as such because of your statements that you are primarily a hand tool guy. Use the little saw at what it does best (rough cutting and ripping) and use your hand tools for everything else.
fence fretting and other thoughts
Bill Tindall, E.TN
>I never understood fretting over table saw fences. So long as they lock securely, in my mind that is all that is required. A 40 tooth very thin kerf blade will be a delight to use on you saw. I have and like the CMT, and another that begins with "S" that I can't remember ( sort of looks like the name of the chain saw Stihl). Freud makes a thin blade that may also be of high quality.
That said, what do you propose to do on this saw that you can't on the band saw? This saw will be fine for ripping but so will the band saw. I don't think you will find it very accurate for cross cutting, and if not you might as well use a hand saw or band saw. It seems to me that a power jointer would have been a more useful purchase to augment your hand tool usage.
>I don't like the Ryobi job site saw. That being said - going for a reasonable thin-kerf blade is a good first step. Anchoring the Ryobi to a secure base and more or less surrounding it with an infeed and outfeed table is another step. The fence is not good. But if you can lock it down securely - who cares that much.
The price was right. That's the good thing.
Larry in NW Ohio
>Michael I have the freud 30 tooth coated blade and of courseI suggest it. I have had other blades, a lot of other blades, and this is the one that gets most use. Larry
Yeah, and next you'll try to convince me..
David Yoho
>...you just bought a new PC with Windows Vista on it ;-)
Knowing you're not one to pass up a good deal, I guess I'm buying this idea, strange as it seems! Sounds like a way to get some of the grunt work done so you can enjoy more time working things by hand. As long as you're not expecting more from this machine than it can deliver, and I'm certain you're not, I think you will find it useful.
Next time you get around to my shop, you may be surprised to find the growing number of hand tools I have here. Remember the Stanley cabinet scraper you had to explain to me? I now keep it and another like it ready to go at a moments notice. I just used one of them on some curly maple panels this past weekend. A real joy to use!
David
>Good Evening Michael,
I don't know if your saw will accept a dado blade. If not, I would invest in some good jigs to help out with other cuts. Cross cutting sled for sure. Maybe another one for mitres, or a spiffy after market miter guage. Perhaps a tapering jig.
George
Bricofleur
>Hey Michael,
I have such benchtop tablesaw too (Delta) that I use when I don't want to change the setup on my contractor saw. They work fine. On mine I had to correct the rip fence by adding a piece of MDF and shims to make it straigth and reliable (see picture). I don't think you have to buy another one. I'm not sure if another one is available too! Buy adding the MDF I was also able to attach featherboards for down pressure.
The weakest point of these benchtop saws is power. You must pay attention to that all the time. Since they are direct drive, the motor cost a lot to replace.
Mine came with a thin kerf blade (36T), probably for the reason stated previously (power).
Do what you did when biking. When it was hard on your legs, you used to swich gear, doesn't it? Do the samething with your saw. Use the smallest diameter saw blade as you can. And don't let the motor heat. And if you use a dado blade set, you will probably be able to mount only a 3/8" set. Here again, buy the smaller in diameter. Or better, use another technique or tool.
And the best thing to remember is, 100 years ago, there was no such saws and the work was done. I'm sure this tool will help you to get the work done faster, but only you can get it done better.
Best,
Serge
www.atelierdubricoleur.spaces.live.com
Re: fence fretting and other thoughts
Michael Bush
>Your question about the band saw is a good one, and has been part of the reason I've never bought a table saw before.
I'll figure out what uses I have for it as I go along, I guess.
Re: Yeah, and next you'll try to convince me..
Michael Bush
>I love those scrapers...
