redwood and fiberglass
wooden leg
>I have been asked to help build a redwood strip canoe. My concern is will the fiberglass bond to the redwood or will the oil from the wood cause it to fail? Should I wipe the wood down with something and if so what?
Thanks, Dave
Re: redwood and fiberglass
Robin Corell in Atascadero CA
>Redwood is not a particularly oily wood. It is very soft and will soak up a bit of resin. You may have to seal it with a coat of resin and let it go off and then apply the cloth with a second coat of resin to avoid having air bubbles under the cloth.
