REAL MILK PAINT
grrr...tablesaw table top problem
Gary
>Ok, so apparently I wasn't playing with a full deck of cards this evening (if you catch my drift). I mis-measured while drilling, and instead of going into the mitre slots on the tablesaw top, my drill bit put a nice clean hole into my unisaw top.
Yeah...didn't exactly make my night.
What do I do with this? Fill it? Just wax it and be done, or treat it somehow else?
Thanks,
Gary
Re: grrr...tablesaw table top problem
Ronald from NW Ohio------WebKitFormBoundaryAAddAAU
>Is it aluminum? If so if it were mine i would weld it and sand it out.
Brian in Brighton
>If it were me, I'd tap a 3/8-16 hole in it and tell anyone who asks that it is a jig mounting hole. You had to pay extra for the precise locating feature and it is a special order that is not listed in any brochure, but you made a few calls and brought in some favors to get it that way.
Otherwise just deburr the top edge nicely and leave it alone. You did no damage to the cast iron top for any purposes that it's used for. Unless that's a 3 inch holes saw or something, the top should not have warped in any way.
Brian in Brighton
Rob Stokes in North Vancouver
>De-burr and ignore it. Tables saws are to be used, not saved for a life in a glass case somewhere.
Use it hard, take care of it well, look at the scars with pride as each one tells a story or teaches a lesson and concentrate on important things - of which a hole in a table saw isn't.
Rob
The way my life works . . .
steve mackay
>anything I tried to do to that would, undoubtedly, end in a MUCH bigger oops than I already had. Besides, I agree with the "story" above . . . You're in the process of building the off-set-adjustable tangent / sine-jig that mounts in that hole. Just got to get around to finnishing the darn thing.
JB-Weld and Duct Tape are your friends
>I'm not quite as tough as the other reponders :)
I'd put a little duct tape underneath (assuming you went clear through the other side) and fill it with JB Weld from the top. Then a fine fine to level it once it's dry.
Happy Woodworking!
Bob Entwisle in NJ
>Gary, Ouch!
I feel your pain at having injured th top of your Uni.
I think that if you just debur/flatten the entry point so it does not interfere with normal operations, it will eventually fade into a subtle reminder to measure two or three times, and then check again before you drill/cut etc.
Bob
>>...nice clean hole
I did that to my finger once (don't ask how). Only it wasn't nice and it wasn't clean.
Jesper, Denmark
Re: forgettaboutit................
Jesper, Denmark
Re: What ?
Chuck in ND
>A Unisaw with an aluminum top ? Isn't this how bad rumours get started ?
>Cast iron can be welded too.
Weld repair? NO WAY!!!
Gene Gauss
>Don't even think about weld repairing it. There is a good possibility that the localized heating from welding would cause distortion that would affect the flatness of the top. Then you would really have a problem. A hole, open or plugged with some body filler or something, is no big deal compared to a warped table.
Near invisible repair
Lee Schierer - McKean, PA
>Forget welding, you can only successfully weld cast iron by heating the entire piece to 500+ degrees before trying the welding.
Plug the hole. You can make a pretty near invisible repair by drilling the hole to the next larger tap size drill and tapping the hole. Then get some red colored (High Strength) Loctite and a bolt that fits the tapped hole. Put the Loctite on the threads and screw in the bolt from below. When the end of the bolt sticks through the top of the table about 1/16" stop and let the Loctite set up. Then file down the bolt flush to the table surface.
You could also do this with a short piece of steel rod that fits tight in the hole, but use the green colored (Wicking type)Loctite. Apply loctite to the hole and to the pin and tap the pin into the table so a tiny bit sticks up, then file it smooth.
The repair will be almost as hard to see as a plugged screw hole in wood.
Lee
Lee Grindinger
Agreed
Lee Grindinger
>If a table saw isn't scarred it's not serving it's purpose. As an occasional owner of old tools I grew to appreciate the scars and signs of wear.
Someone should tell you the Tage Frid one-dollar-for-a-boo-boo story..., it's pretty funny.
Drill 3 more and...
Grant in Iowa
>Then tell the wife you need a power feeder!
ROFL !
steve mackay
Re: Near invisible repair
Fred Davis
>That's a good idea Lee, I was wondering about a tapped plug and you took it to it's final conclusion.
As for the guys who subscribe to the notion that your not really a woodkworker unless your saw tabletop looks like Flanders field, you gotta wonder what they say when the litte woman starts the conversation with "Honey , I borrowed your new 45,000.00 vehicle to got to the supermarket and well.... you know how tight those little parking spaces are".....
FredD
Ralph in Huntington Beach
>I couldn't agree more!!!
"As for the guys who subscribe to the notion that you're not really a woodkworker unless your saw tabletop looks like Flanders field, you gotta wonder what they say when the little woman starts the conversation with "Honey , I borrowed your new 45,000.00 vehicle to got to the supermarket and well.... you know how tight those little parking spaces are".....
FredD "
Lee Grindinger
Trophy saws
Lee Grindinger
>What we have here is a very different way of looking at things. I made my living for 30 years building furniture. A saw was a tool, a tool that was not coddled, it was used. What you guys have are trophy saws and don't get me wrong, there's nothing wrong with viewing a tool that way, but I can't think of any professionals who do.
This is not to say professionals abuse their tools often, most do infrequently when deadlines and other pressures insist upon it. But when that gritty lumber needs to be ripped it needs to be ripped even it it scratches a table and dulls a blade.
Perspectives are quite different as you can see. By the way, to be fair, it would be more like my wife taking my pick up (93 Chevy WT) to the store, scratching it, confessing it to me and hearing "So what." from me.
You guys must have really nice table saws to compare them to a $45,000 automobile.
Lee
Re: Trophy saws
>I'm not a pro, but I buy my tools to use, my chain saw chains to wear out, my cars to drive and my boats to get wet - in and out!
My table saw gets waxed all the time, and the odd deep scratch gets sanded out. But it's got marks, warts and stories...all of which will be passed on to the next guy who buys is. And it's tuned to within a hair of anything you can measure - that's what counts.
Re: Trophy saws
Fred Davis
>Well , not to put to fine a point on it , Lee , I have used saws for about fifty years, and the Cabinets and Furniture were never made from "gritty lumber"
I go back to a time when Carpenters tools were inspected by the foreman before they were hired , saws didn't have guards, edge tools were kept shiny and sharp and it was considered that the quality of your work was directly related to the quality of your tools.
I have seen the table saw used for a workbench many times , by people who didn't appreciate how much easier the tool is to use if it is kept in good condition.
Rusty tabletops are common , but I never heard it said that it was a prerequisite to doing acceptably good work.
Same goes for workbenches, hand tools and any thing of value in the shop, it works better with less strain and reflects the approach the workman has to his work.
Why would anybody buy a PM66 table saw with a $300.00 Blanchard grind on the top and treat it like a anvil?
Beyond my comprehension.
FredD
Tools = users, for me
Gary Camp, Bend, oregon
>While I would never deliberately abuse any of my tools, I do buy the to use, hard if need be. I suppose I'll never own a saw with a 300 dollar ground top, just like I'll never own a fancy workbench. I'm to likley to screw a jig or fixture right to the top. If I were to drill a hole in the top of my saw, I'd be mighty disappointed in my self, I might even so OH S..t, but life goes on. Oh by the way, I suspect Lee might just be playing a bit of Devils Addvocate here, I do remember the look on his face and his reaction when Lisa, (who really did know better) set a wet canned beverage on HIS tablesaw. He looked a bit surprised, and and quitely, politely asked her to move it while he just a quietly wiped the water.
glc
Exactly!
John in NM
well said!
Bill Tindall, E.TN
>If the focus was on making stuff, these problems would not be important.
It reminds me of the "Shop Contest". As I suspected, the focus of the winners was on making a fancy shop, not superior furniture. It still gives me pause to see the spartan shops (and tools) that most professionals use to turn out magnificent stuff.
an excellent idea and my JB-Weld story
Bill Tindall, E.TN
>I bought an aluminum pot for backpacking and found it had a defect in the bottom that resulted in a leak. I was about to leave on the trip so I tried putting JB weld in the hole in hope that it would hold for the trip. Now this pot gets set on the fire and stove to cook stuff. Well 30 years later it still fills and seals the hole and I have had the pot of a fire dozens of times. Because JB is gray, I have to look close to detect the repair.
