Electric height-adjustable desk questions *LINK*
Paul Cates - Henderson, KY
>Hello everyone,
I'd like to construct an electric height-adjustable computer desk but haven't found much info after searching the internet. I found a kit to make one which uses electric cylinders (see link below), but it is $$$. I do want the ability to push a button and have the desk move up or down, but am wondering whether there is a less expensive way. I like the electric cylinder idea, but have no idea what parts I'd need in order to put the pieces together. Thoughts?
I am also open to other ways...maybe a couple of scissor jacks from the junk yard connected to a drive shaft? I have racked my brain and haven't come up with much.
Ideas and comments welcome,
Paul
Electric Lift Retrofit
Re: Electric height-adjustable desk questions *LINK*
John McGaw
>How much work are you willing to put into the project? I can think of a few ways to do the task.
Most attractive to me is a reversible gearmotor driving a cogged belt which drives four (or two depending on the desired design) lead screws. On the lead screws are the requisite anti-backlash nuts which, in turn, support the movable part of the desk. Range of motion is dependent on the length of the lead screws. All of these materials should be available through various surplus dealers.
Or a gearmotor driving a drum with four strands (or two) of 1/8" aircraft cable which, via pulleys, serve to lift the movable part of desk. Again, surplus dealers are the place to go although the drum might have to be made on a lathe.
Or you could just search for linear actuators.
Gary Camp, Bend, Oregon
>I would avoid anything that involve hydraulic fluids. Sooner or later they will leak. I would think linear actuators with appropriate hardware and circutry would do the job.
glc
Howard Norman
>I would agree with Gary, I wouldn't want hydraulic cylinders because of the leaks that will occur over time.
>Johh, I didn't know the exact term for what I wanted, so thanks for saying "linear actuator." Having the correct terminology greatly helped my search. I like the linear actuator idea to conserve space because my current thoughts are to use four of them - one for each corner of the desk. The rear acting independently of the front in order to tilt the desk.
While my budget is not unlimited, I will spend the necessary $ to improve my desk ergonomics since my back and neck are killing me.
mdclor
>Paul,
I don't know if you would be interested, but there was an article in FWW #179 showing the construction of an adjustable drafting table. It could be set at 8 different positions, from sitting to standing. I think it could be modified for greater adjustability if needed. Just a thought.
Merle
Neal in San Jose
>Another thought: We have several desks that are electrically adjustable at work. I've not bothered to see how they work, but you might call around to the second-hand office furniture stores, which seemed to be pretty packed right now, to see if they might have something you can either use as-is, or canibilize for parts.
Carol - now back in Dubuque, IA
>I used linear actuators (12V) with Accuride drawer slides for guides when I made an electrically adjusted pulpit for wheelchair bound folks a few years ago. I used a computer interrupter power supply (12V battery) with an AC adapter to charge it. They could raise 100 pounds which way more than enough for my purposes. I did have to design in limit switches to control movement so that it didn't self destruct by going too far! I used rocker type momentary contact switches to control direction.
The linear actuators came in 3" increments and average $100 a piece. I don't remember the source any longer and my records are in another state. Google linear actuators and look for a source in Washington state.
Holler if you need more sources for switches and stuff. My application is used in a public (church) facility and so comes under some codes. Thus I used very high quality (aircraft) electrical stuff. You will need to make an electrical source voltage decision first. Then you know what you will be needing along the way.
One word of advice. Get your electrical stuff before you begin. And your guide hardware. You will need to design around all that stuff. If I had to do it again, I would build the function structure first and then the aesthetics (making it look like a desk). I wound up with my brother welding together a metal infrastructure to fit. He swore never again! Function before form was his argument.
Here is how it turned out. Sorry I have no pictures here of the interior infrastructure.
Larry in NW Ohio
>Carol That is a very beautiful pulpit, just wanted to comment on it. Larry
Larry in NW Ohio
>Paul There is a place I bought a few thing from that have the actuators you are looking for. www.surpluscenter.com Larry
>Carol,
I think your source in Washington is Firgelli - they have lots of info on their site, plus some excellent videos on Youtube. Thanks!
>That's the place!
Thanks for finding it.
Al Stokka - Cambridge, Iowa
Paul,
Wouldn't the simpler (and cheaper and quicker) solution be to buy a chair with adjustable height?
Respectfully,
Al
>Hi Al,
Thanks for your suggestion, but my chair is an adjustable height one. I spend a lot of time at the computer and I've (finally) realized that my aches and pains are from poor ergonomics. I saw the desk at the link below (in the top left corner of the page), and think if I can recline a bit with a tilted top, or even stand up, many of my aches would disappear.
Anthro.com
