We value your privacy.
>I'm sure this has come up hundreds of times, but I couldn't find it doing a search of the messages. What is the easiest/best way to clean a table saw blade (dado stack)? I seem to remember someone saying to use "Simple Green" but am not sure. I have a Freud sd-508 that I acquired as ebay booty that seems pretty darn sharp, but has quite a bit of pitch on/around the teeth, and I don't want to use it till it's been cleaned up and evaluated first. As a second question, can anyone reccomend a sharpening service, in case I find the need for a freshening of the cutting edges? As always, thanx to the collective for your help and advice.
>I soak mine in a diluted solution of Simple Green for a few hours. I have some small copper wire brushes I use to scrub the residue off and rinse. I do the same with my sanding belts only let them soak overnite.
>I'd say the majority of the responses I've seen recommend using Simple Green. However, I'm still of the opinion that a short soak in common household ammonia is just as effective, requires little scrubbing with an old tooth brush, and costs less. Of course, there are those fumes! I deal with them by being fortunate that my utility sink is so close to my walkout door.
>Pitch will dissolve in anything basic, which includes ammonia. Just don't leave it to soak for longer than necessary. A short dip in ammonia and brushing will promptly remove the pitch. I suspect Windex would work for the same reason and many recommend the green stuff.
For sharpening Misenheimer 423 587 4300. They sharpen and make tooling for the furniture industry. It is a safe bet to get stuff sharpened at a place that can make it.
>Microscopic examination of polished carbide has not revealed the reputed damage of carbide by ammonia. Maybe if left for a week......but it dissolves pitch so readily that it doesn't need to soak very long.
>The strength of ordinary household ammonia is not the same as the stuff used in industry and, therefore, while a good whiff from the fumes will get your attention, it won't kill you. I don't think it would be on the market all these years if it was so.
As Bill stated, you don't have to really soak a blade or router bit in ammonia for very long before the crud comes loose.
I put the stopper in my utility sink (used a plastic pan for a time), lay the blade in the bottom, pour enough ammonia in to just cover the teeth, and wait about 5 - 10 minutes. Usually when I'm doing this I have other things going on in the shop at the same time. I leave the blade until I'm done with whatever else I'm doing and then go around the teeth with an old tooth brush to remove anything that hasn't come loose by itself. Pull the stopper out, rinse with water, dry it off, and place it back on the saw clean as new. The time spent standing over the sink is minimal and the fumes tend to be too. If they are strong, I just open the nearby door. However, I usually don't need to ventilate when using the ammonia.
Chlorine bleach is toxic too but many use it as sold in its diluted state for laundry. It's the full-strength stuff that'll get you. Oh, and never ever mix household ammonia with household bleach - those fumes absolutely could kill you!
>It would seem that we have arrived at a point where anything that has an odor is presumed to be a "toxic chemical" with everything from cyanide and ammonia lumped in the same category. Chicken farmers, should there be any listening, must be amused by anyone fearing the odors from cleaning a saw blade.
Should you faint, guess what the EMT will stick up your nose, presumably to revive, not kill you.
For those not chicken farmers or others that muck out animal pens, chicken poop, as well as sheep urine, contains urea which hydrolyzes to ammonia which accumulates to considerable quantity in the manure. When mucking out a sheep pen or chicken house the odor from ammonia can be breathtaking. It might be possible to simply suspend saw blades from the rafters and they would self clean.
Personally, I find ammonia, unaccompanied by sheep poop, a pleasant smell.
>Although many materials like ammonia, oven cleaner, can remove pitch or resin deposits, they may have fumes, or have potential (oven cleaner) to react with the brazing material.
I prefer a product designed for the purpose. One I have used is sold by Lee Valley Tools. See link.
This has no fumes, apply, let sit for a short time and it will dissolve the deposits.
As another reply stated, I use old tooth brush to work in the cleaner. Always have several around.
Rinse with warm water, then I apply Boeshield to prevent rusting. Some blade material more reactive to moisture than others.
As for sharpening. You cannot go wrong with sending the dado stack to Forrest or Ridge Carbide. Lots of people have positive comments on Forrest. My last blade sent for sharpening was a Ridge RAS blade. Came back clean, sharp and looking like the teeth were polished.
>I also soak my blades in sudsy ammonia, just long enough to loose the crud. 5-10 minutes usually does it. I scrub the teeth with an old toothbrush and then rinse in clean water.
>Oven cleaner. Bad idea. Toxic as all get out. And breaks down the binders that hold the carbide together.
I use a router bit cleaner from CMT. Spritz one side. Turn it over spritz the other. Turn it over, brush with a stiff scrub brush. Flip is once again. One more flip, one more brush. Rinse under the faucet. Hang to dry. Just that quick. If you've left it to really get gunked up, then a couple minutes soaking on each side after spritzing. Don't do that. Old time sharpener told me years ago that most blades that came in weren't dull, just dirty.
As it is, it'll take forever to use up that pint bottle.
Definitely avoid oven cleaner and other caustics. They attack the cobalt binder in the carbide and can lead to carbide failure (translates to tiny missiles of carbide at 100+ mph). Also, Freud and some other brands of blades have a tri-metal brazing foil that uses copper alloy for a cushioning layer. The copper can also be affected by these cleaners (translates to larger missiles of carbide). We recommend soaking overnight in kerosene in a vented container and using a stiff nylon bristle brush to clean. Teflon coated plates will clean up with a soapy cloth (except for the teeth as mentioned earlier). There are commercial blade cleaning products that are not caustic but we don't officially sanction them.
The manufacturers of Simple Green recommend NOT USING their product for carbide tool cleaning. Freud recommends using kerosene.
Re: Thanx for all the great, and interesting, resp
Jim Dillon
>Stuart,
Like Carol, I picked up some CMT cleaner several years ago and have have had good luck with it on both my TS blades and router bits. Don't know what is in it, but it seems/smells fairly benign.
>There seems to be some confusion about whether alkaline chemicals are harmful to carbide. They most certainly are, but mild alkalis (simple green) are less harmful than highly caustic ones (oven cleaner). Household ammonia (the 5% variety) falls somewhere in between.
When I visited Freud's carbide plant and research laboratory in Udine, Italy, Giorgio Pozzo, then the heir apparent to Freud, demonstrated the effect of a strong alkali (he used sodium hydroxide) on a sample of polished carbide. He put one drop on the polished surface for a moment and then rinsed it off with water. There was a clearly demarcated round dull spot on the polished surface where the sodium hydroxide had been. The binders they use to sinter the carbide are indeed susceptible to erosion from bases (alkalis), as is the brazing metal that connects the tips to the blade plate. You wouldn't see this erosion without an electron microscope, as the tiny balls of carbide are less than 300 angstrom units in diameter.
In the practical sense, using a mildly alkaline cleaner like Simple Green or Windex will not visibly or effectively do damage to your blade. But, at some level, it will react with the binder. Eventually, a few of those tiny carbide spheres will become unsupported as a result and your blade will lose something of its original sharpness. You might not even be able to perceive this degradation, but it will be there. My sense is that anything that makes my blade dull faster is to be avoided, but mild alkalis are not as caustic as concentrated ones, and you might never notice any effect at all. It's all a matter of degree.
>No one is suggesting using sodium hydroxide as a blade cleaner.
Comparing the effects of sodium hydroxide - probably quite strong sodium hydroxide - to household ammonia is roughly like comparing the effects of sulfuric acid to acetic acid - one is sprayed on rocks to disolve the copper in them, the other is sprayed on salad to make it tasty. If you sprayed vinegar on the copper ore, a very, very tiny amount of copper might disolve in it - but more likely it would evaporate first.
By all means, everyone clean their blades with whatever they want (the kerosine soak is a very good method). But this sort of demonstration is not science and is loaded in such a way as to be extremely mis-leading. I've no doubt that Freud's intentions are quite good, and perhaps they honestly think this demonstration means something. But by this same logic everyone should avoid touching vinegar!
