QSWO Dining Table
HC Sakman will be @ Victoria LV APRIL 13th.!
>Hi Again,
This piece also went to the same home along with the cherry/rosewood entertainment console posted below. 50" round table w/ 19" wide folding leaves. The flakes in these boards are pretty spectacular. Top is 15/16" thick. Center of the base is 5" square. In between the double beaded edges of the base are concave profiled. Center leaves hinged with Soss hinges, syncronized top slide is from Hettich.
Embedded rare earth magnets holds the extension leaves or the two halves of the top together without any locks under the top or the leaves.
Stained w/ Mohawk medium dark walnut then 2 coats of conversion varnish sprayed.
Chico...
