joiner not right
joiner not right
joiner not right
eliot d------WebKitFormBoundaryu+MBDi+0MX0Pf5O9---
>I started with a perfectly rectangular board about 3x3x14 inches and ran one face through my joiner about four times to see if it remained all square. It didn't. It's slightly thinner at the rear of the board -- the part that passed the joiner knives last. What's wrong, please? And how would I adjust a typical 6 in Delta joiner to fix the problem?
Re: joiner not right
Dick Coers
>The purpose of a jointer is to make a surface flat and then an edge square to the previous face. It does nothing to make parallel surfaces. Now if the board you ran is not flat, then you have a problem.
suggestions
Bill Tindall, E.TN
>The probably cause is simply that it is easy for one to put more pressure on the trailing end of a board that the leading end, especially so for something short. Do the experiment over except joint the edge of something longer and see if the width remains the same.
Alternatively, the out feed table may be a a tiny bit high. It can't be much too high or the piece would butt into the leading edge of the outfeed table and not feed through.
I agree
Bricofleur
>I agree with Bill's answer, particularly if your stock if still square when done. I also have a 6" Delta and I must pay attention where I put the pressure down when feeding the stock. In fact, not much down pressure is needed; just to keep the stock down on the table, but tight against the fence and feed. The most pressure must be on keeping the stock against the fence to keep it square.
Another suggestion: Get use to it feeding several scrap pieces.
Best,
Serge
www.atelierdubricoleur.spaces.live.com
sounds like tables are out of allignment
Robin Corell in Atascadero CA
>The cause of your problem is the infeed and out feed tables are not co-planer. you will need a copy of the manual for the machine and a good 36" straight edge, preferably two straight edges. each machine is different but the manual should walk you through the steps to get it back in allignment.
Robin
PS
Bill Tindall, E.TN
>I have never been successful reducing the thickness of a board on a jointer and keeping the thickness constant. The problem is that keeping uniform pressure on a wide piece (wide relative to normal edge jointing) is very difficult.
Re: sounds like tables are out of allignment
>Thanks for helping me out. I'll dig out the manual and make some fine adjustments. I don't think I'm applying the downward pressure unevenly.
Fred Davis
>Eliot,
If is a DJ-20 about ten years old or somewhat less with parellelgram adjusters and eccentrics for coplanar adjsuting, you may find your missing several pages of your owneers manual, which Delta is aware of and can download it to you.
That is what I have and what happened to me and now , I need to readjust the infeed table eccentric , which has dropped again, enough that a straight edge will bump into the outfeed table , next to the fence.
It took a Millwright who does this all the time for a tool dealer in Lenexa a hour and a half, the first time.
I don't envy you at all if that is the model.
FredD
jointer + planer
del schisler
>i belive a jointer is just that edge's a board and not a planer as we all know It is very hard to hold the board down on the blades with the same preasure all the way across the board I guess you can run it across to knock the saw marks off and see what the grain look's like Than a plainer is the next tool to use my 3 cents worth
>Eliot, My understanding is that the jointer has basically two functions. To flatten one surface of the board probably without using the fence. And to straighten one edge and make it square tot he face that is run against the fence. (Obviously, it can do a lot more, but those are the basic two.) To get two surfaces of the board flat and parallel to each other, you flatten the first side on the jointer and use a planer to flatten the second side and make it parallel. If your machine is doing these two things well, you are in good shape. If the outfeed table is set too high, then the work piece will bump into it when you joint it. (A crisp square corner on the leading end of a piece of hardwood will reveal this quicker that a ragged end on soft wood.) If the outfeed table is too low, you will get snipe as the piece clears the infeed table. (a dip in the end of the piece that equal the distance from the end of the infeed table to the centerline of the cutter head. An 1" to and 1 1/2" "long" and the depth will be determined by how much too low the outfeed table is.)
I know some of us here use depth gauges and measuring devices with magnetic bases and knife setting systems and all kinds of fancy stuff, but I don't. I set my knives all to the same height, using a steel ruler on the out feed table. I adjust them so that the knife touches the ruler, lifts it very slightly and moves it forward a given distance on both ends of each knife. That is, I sett eh rule on the bed so that a known mark (2") is at the leading edge of the outfeed table, roll the cutter head by hand, and watch the rule, without touch the rule. If it moves 3/8" or whatever on both ends of all the knives, I quit fiddling and tighten the knives and check again. Then I joint a nice piece of hard wood with a sharp square end. I raise or lower the out feed table to make it work right. (no bumping and no snipe.) If you raise infeed table to zero you should be able to lay a straight edge (a good one) along both edges of the tables and they should be flat and in the same plane.
This may not be the most scientific way to do it, but it works for me. Its woodworking. Perhaps I am missing something, but I have never found a place where a few 1/10000" mattered.
So, I am guessing your knives are already set to the same height and you can adjust your outfeed table and move on.
>I just checked; it's a DJ-15.
