Latest Work--Cherry & Rosewood EC
HC Sakman will be @ Victoria LV APRIL 13th.!
>Hi Everybody,
This was going to be a simple entertainment console. Initially, bottom shelf was going to have ventilation slots, but later on I thought I can do better than that. Doors were obvious targets for this change in design concept. After redesigning the doors with air intake slots, simple and straight lower stretcher was in need of following the doors somehow. This is the result.
It's 19" deep, 54" wide (top) and 31" high. Trim around the side panels and glass, as well as the handles are from the same piece of rosewood.
Then I put the "simplicity" behind and book-matched all of the cherry parts of the front.
This is after the electronics are placed on the shelves. There's a 54" LCD TV mounted on the wall.
All of the case and door frame members are joined with loose tenons.
The sides feature "bent" panel, following the shape of the legs. I haven't seen anything like it as in frame&panel construction, so in my mind it's unique. I am sure somebody else had done this before, though nevertheless, it's not commonly seen. If you've seen something similar, I'd like to know.
Top is made of two 12" wide boards. Only the ends are beveled, the rest of the edges received 1/8" radii treatment. Finished with many coats of hand rubbed oil-varnish mix.
Thank You.
Chico...
