Cross Sled
Cross Sled
Cross Sled
Gfriend
>I have a large cross sled from Woodhaven I purchased several years ago. Recently I am having problems when I cut wide pieces (say about 25 inches)and I'm cutting the length to a specified cut. The length on one end is longer than the other by about 1/32 of an inch. I have checked the squarness of the fence & have clamped down the work piece. Is there anything else I can check or put another way..what things should I check?
Re: Cross Sled
Re: Cross Sled
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>A blade which is duller on one side will vier to the path of least resistance. If you are pretty sure nothing else has changed, I would try another blade.
Also, Make sure there isn't a little crumb of saw-dust stuck in the corner of the fence and base. It is not unusual to jamb a small piece there.
Otherwise, knocking the saw table out of alignment with the blade is a remote possibility, but possible if the nuts are not good and tight, or if the saw took a major jolt.
Re: Cross Sled
Re: Cross Sled
Don Evans
>Couple of questions first:
1. which side is longer, the side that is cut first or second?
2. what tool and method are you using to determine you are set up square?
If you are using a carpenter's square have you checked it for alignment? If you are not familiar with procedure I'll pass it along.
I'm not familiar with that particular sled, but what about wear on the runner? Also, 25" is pretty wide for a standard home type saw like the Unisaw etc, what equipment are you using?
Don
Re: Cross Sled
Re: Cross Sled
Jim Dillon
>Another trick to test whether or not something has gone amiss is this. Take a squared-up piece of wood roughly 3/4 inch thick, 6-8 inches wide and maybe a foot long. Place the edge against your sled fence with the intended cut roughly in the middle of the board. As another poster said, make sure there is no sawdust etc. between the edge of the board and the fence. Cut the board into two pieces. Then flip one half of the board over and butt its edge against the fence and flush to the adjacent piece. If your sled/blade are OK, then the two pieces will align perfectly with no gaps between the boards. If not, then something has gone askew, especially if the sled was working before. This test exaggerates any misalignment.
Now for some guesses why you are having problems. First, as previously stated, check for sawdust/chips behind the board. Second, are the sled runners still running smoothly in the TS miter slots with no side-to-side slop? Any sawdust between the blade and arbor? When this happens to me, and it has, it is always sawdust behind the board that is the problem even though I cut a small 1/8 inch rabbet in the bottom of the fence to catch the dust. And make sure you are holding the board tight to the sled fence so no slippage happens. Anyway, just some thoughts. Hope this helps.
Jim
Re: Cross Sled
Re: Cross Sled
Ed Mulligan, Cape Cod
>More suggestions: Slow down your feed rate. Make sure the fence is straight. Make sure the workpiece edge that registers against the fence is straight.
Re: Cross Sled
Re: Cross Sled
Larry in NW Ohio
>GFriend You may try putting some sticky backed sandpaper on the driver front by the saw blade and just about at the end of the piece your cutting. This will help keep your piece from sliding when cutting. Larry
Re: Cross Sled
Re: Cross Sled
Gfriend
>Wow ..thanks for the feedback....I'm going to chek all that each person mentioned ....I do think its a long cut for the table saw & cross sled & do think there is a little play in the tracks...
Re: Cross Sled
Re: Cross Sled
Jim Dillon
>I was thinking about this more after I posted. Does your sled have wooden runners and, if so, was it built during the more humid summer months? I've noticed that some of my wooden runnered sleds/jigs etc. sometimes are looser in the TS miter tracks during the lower humidity winter months. Nothing real significant, but I wonder... ? If so, then maybe just a little masking tape here and there might tighten things up. Hope you get the problem resolved. Let us know if you find the solution and what it was.
Jim
