OT Removing Caulking from truck seat
>Working on remodeling a bath room, Installing a four piece Fiberglas shower. Called for excellent quality mildew resistant silicon caulk. Managed to get some on my fat arse and then went and sat in the truck. Anybody got a good idea how to get fully cured caulk out of a fabric seat? I guess it could have been worse. If the ride home had been longer I might still be glued to the seat.
Re: OT Removing Caulking from truck seat
MAPP Torch
GalenV in Iowa
>They market a silicone caulk removal jell but I have not idea how it may work for fabric or leather or whatever your uphostery is.
It may just make the spot worse but do not know till you try.
If some type of synthetic it may soften your seat covering!
Galen
Not much help!
>Where would they sell such stuff? Guess I would want to be real careful about removing all the gel. Wouldn't want to find out how it affects butts that are sitting on it.
Hey! it's a Truck! Don't Worry About It.
Dave Andeson (PacNW)
Joseph Mulherin, Sr
>Barry, it is time to put on some new seat covers on that old truck....give it some "life".....
GalenV in Iowa
>I have seen it at our Lowes and I would think any good home improvment store should have. This is what DAP says:
DAP� CAULK-BE-GONE� Caulk Remover Specially formulated gel softens latex caulk for easy removal. Fast-acting formula, works in as little as two hours. Fresh scent. Will not harm surfaces. Use for indoor and outdoor applications.
Bad Info ----Sorry
GalenV in Iowa
>I thought what I had was DAP. Should look before I write. DAP says in one place for all type of caulk but then later says NOT for silicone!
This is what I have but in reading details don't think you want to try on your truck seat. On the newer bottle I have it ate the front label!
Again sorry for other info.
Galen
RHeat maybe
Larry in NW Ohio
>Barry Would heat from a heat gun or hair dryer work. But the bad thing is what do you do after you get it heated up and soft. Larry
Tim Caley
>I know a trick for removing chewing gum. It may work for this as well. Go to Walmart to the electronics section and buy one of those cans of compressed air. Turn it upside down and spray it on the caulk, and it may work by freezing it. Then scrape it off with a dull knife, credit card, etc.....
