Which multi-tool for tile removal?
Richard Krieger
>I have checked archives, but wanted opinions on which "multi-tool" has the best reputation for removing an existing ceramic tile applied to a "mud bed"? I have looked at Dremel, Festool and Fein's newest models. I would want to use the tool after the tile repair for primarily woodworking. Each tool has various "accessories" for tile/grout removal, but does anyone have experience with the removal of the thinset using the adapters?? The videos all seem way too easy! Any help/opinions is appreciated.
Thanks,
RLK
Re: Which multi-tool for tile removal?
Dremel vs DeWalts
>I've had a couple of Dremels and have a DeWalt drywall cutout tool. While the Dremel is handy, it's pretty weak compared to the stronger DeWalt. The DeWalt has mutiple collets so it can use all the same bits that a Dremel can use.
Happy Woodworking!
I'm a Fein Multimaster fan!
Glenn Madsen near San Francisco
>Bought one for ceramic tile master bathroom, and it proved itself over and over. It gets used for woodworking, when I need a power detail sander, or a thin saw cutter, or something quick and strong.
I have a RotoZip, which gets used about once every 4 years, and with good reason. $125 I'll never see again...
You're not trying to save the tile you need to pull, are you?
A Wright
>I have removed a few bathroom tiles before by drilling a hole in the middle of the tile and then prying/breaking it out with a screwdriver. The hardest part about getting the tile out is getting "under it" without chipping the neighboring tiles. Once you have the tile removed, you shouldn't have much trouble cleaining up the area for a new tile with an old chisel or a stiff putty knife.
Joe Shelton
>The only good tool I have for the task of removing tiles is the Hitachi circular saw, running at 11K rpm, and fitted with a 4" diamond blade.
Bought a MultiMaster kit. It came with a carbide blade intended for cutting out grout, but it is very slow compared to the circ saw, and the carbide is wearing very quickly.
My process is to remove most of the grout surrounding a tile to come out, then to break out the tile. Removing the thin-set is a chiseling mess. If your thin-set is actually over a mud bed, you're in for a tedious chore.
In defense of the MultiMaster, I still have high hopes for it when working in wood trim refits. It certainly is a high quality tool.
None of my router tools (Dremel, cut-out tool,etc.) has been helpful with grout.
The only tool in this mix that can actually cut tile is the circ saw. I've been able to use it with plunging cuts to insert small "inlay" pieces.
Joe
Justin Szeliga
>4" angle grinder w/diamond blade. Works for me so far.
Peace
JJS
Richard Krieger
>Thanks to all who have replied so far. I am trying to avoid conflicts with SWMBO regarding dust from a grinder. I know that would probably be the best, but..............
I knew that putting in the mud bed was the "best" way of laying down a good sub-base for tile, but now, I'm not so sure that I should have? To answer one post, "no, I'm not trying to save the tiles".
Thanks again.
RLK
Fred Davis
>Richard had the right idea , he just didn't go far enough.
Remove the tile like professional tile setters do , using a 1/4" masonry bit ,chucked in a drill motor, drill a hole near each corner (about a inch away ) and one in the middle and the tile will pop right out.
If you removing more then one , like a bunch or a old tile job , get one out and then using a Mason's brick set, set against the edge of each tile, give it a swat with your dead blow hammer or mallet.
A little practice and this becomes fast.
FredD
Frank Mutchler
>Fred, why does the tile just pop right out?
Fred Davis
>Frank,
oops wrong term , you would need to tap it in the middle after drilling which fractures the tile into relatively equal segments which can be removed easily with a putty knife , fingers and so on.
One of the things that works against fired ceramic tile is the face of it is technically glass which fractures very easy once the stress of the firing is relieved by drilling holes in it.
FredD
