200+ woodworking book reviews
Cherry Burl Advice?
Cherry Burl Advice?
Cherry Burl Advice?
JohnM in Mid Mich
>Attached photo shows a burl on the lower trunk of a cherry tree that blew down in a tornado last year. I included my peavey for scale, but anyway it is about 18" from top to bottom and about 34" circumference (only part way around trunk). Is it big enough to do anything useful with it? What would that be (turn? slice? carve?)? How would you proceed to harvest it? I've end sealed the ca. 8' long piece of sawlog for the moment. I've done a fair amount of lumber milling and drying, so I'm not asking how to do that, rather, does this look like something special and worthy of special treatment?
Thanks.
Re: Cherry Burl Advice?
Only one way to tell for sure
Gary Evans Tallassee, TN
>Nope, absolute junk!
Cut it out of that otherwise useful log and I'll pay the shipping to get it out of your way. 8^]
Actually, there should be some very pretty wood in that chunk that could be used for turning, inlay, flatwork boxes, knife handles, etc. Burl wood is difficult to dry without degrade, but well worth the effort.
Gary
Robin Corell in Atascadero CA
>I've been milling a lot of walnut from an orchard lately and have run across a few burls. They are not 100% predictable like say milling for crotch figure is. Most seem to have the spectacular figure in the part of the burl you see and then tapering in the shape of a cone into the log. I milled one that looked really promising and was nothing once I got into it.
Burl dries very different from flat or quartersawn wood with uneven shrinkage and sometimes internal voids/checking. these can easily be filled and are seldom structuraly a problem. I will be sealing the entire face on the next one I mill to try and get less internal checking.
Robin
Ken Platt (granby, CT)
>To me, just about any funky looking wood is worth playing with to see if there is some neat stuff inside. Generally, what I do is cut the ends so I can get it on my bandsaw in a vertical position, then slice it to see what's there. For this piece, I suppose I'd cut the log so that I had just the burl section, then carefully start to slice it. With that configuration, you have to be careful because at first the bandsaw is cutting the outermost edge and so is unsupported. If the piece tilts from the downward force, you'll kink your blade - DAMHIKT.
It looks from the pic as though the burl is circumferential. I had one large load of ash burl with that sort of pattern, and it was hard to get usable burl pieces that could be much more than pen blanks, or other smallish turnings (the knife handle idea was also a good one). OTOH, if you turn, there's some very nice potential there. You might want to post in the Turning forum, those folks harvest this sort of weird wood all the time.
Ken
