Drilling Deep Holes
Woodie49
>Does anyone have a good way to drill deep (Long)holes? I need to drill a 5/16"dia. hole in a pice of 3/4" wallnut 7" deep?
Thanks, Larry
Drilling Deep Holes
Woodie49
Thanks, Larry
Re: Drilling Deep Holes
Del Williams
>Sounds like you need a ship auger. Should be available from a variety of online or home center sources.
Woodie49
>I have a long drill bit, but it woun't stay centered.
wooden leg
>Try going to your local supply house for electrical contractors. I have had good luck finding long bits that stay centered. Dave
Bricofleur
>Home-Depot sells 18" long bits made by Irwin in different sizes. Around $15 CAN each.
Best,
Serge
www.atelierdubricoleur.spaces.live.com
Phil Joines Krum,Tx
>Sounds like you're drilling pen blanks. If you have a lathe, chuck the wood in the headstock and the drill in the tailstock. For some reason spinning the wood with the drill still seems to drill straiter.
Woodie49
>The Walnut I'm drilling is 3/4"x2 3/4"x 71/2" drilling long ways.
Larry
Pete in Holland, MI
>Is your drill sharp, and each cutting edge the same length? If the grind is unbalanced, with one longer than the other (point off center), the drill will cork screw itself into the wood.
5/16" x 7" long is a very deep hole to drill in wood. Variations in hardness of the wood can also cause a drill to wander, regardless what you drill it with.
Can you rip the board in half, make saw cuts, and glue it back together (results in a square hole)? Just a thought.
GalenV in Iowa
>If you are drilling a 7" long hole in a 7 1/2" long piece can you drill from both sides and plug one hole?
