Drilling plexi-glass
Edward in Vancouver
>In my "other life" I make chocolates for a living. I had some success in making chocoalte molds with plexiglass- basically a grid of "stiles" and rails" joined with 1/2 laps. The plexiglass is food grade, and very smooth which is ideal for chocolate.
My next challange is to make round molds. I though of drilling 1" holes in a sheet of 5/8" plexiglass to give me the round shape, but I get rough edges. I've used decent, new, HSS L.V. Forstners, and a varieity of speeds on my drill press, even tried flooding the cut with water during boring, but I still get fairly rough edges. What I'm after is a glass smooth edges.
Any suggestions out there?
Re: Drilling plexi-glass
Scott in Montana
>A friend of mine is in the custom plexi aquarium business and he suggests you sand them with wet/dry sandpaper, or if you're in a hurry you and smooth them easily with a hydrogen torch. He says the torch will smooth them perfectly.
Scott
Carol - now back in Dubuque, IA
>The Forestner may be the very worst bit to choose here.
Consider this: The heat melts the plastic leaving a very ugly hole. If you look closely at a bit especially ground for cutting plastic, you would find the angle quite steep. The trick is to do get the waste out of the cutting area as quickly as possible. The less time in contact with the cutter, the less heat, the less melting, and the cleaner the hole.
When I was making and selling router jigs I had to cut larger holes than 5/8". What worked the very best was routing them out with a spiral cutter.
So make a placement jig, 1/2" MDF works well. Drill the hole big enough to accommodate a collar guide, plus the amount to be removed. Install the guide in the base plate, and a spiral cutter in the router. Drop the router in and rout in a clockwise circular fashion with the collar rubbing on the MDF. What is left is your nice clean hole.
If you need help with the math part of this, give a holler.
Use 1" ID acrylic tubing instead
http://www.mcmaster.com/#acrylic-tubing/=17vxfd
Re: http://www.mcmaster.com/#acrylic-tubing/=17vxf
Edward in Vancouver
>Looks like tubing pieces "sandwiched" between two sheets of plexi would be the easiest adnn best way to go.
I never really made "proper" friends with the router. I do have a 2 yr old Milwaukee that usually only gets used for round-overs. Maybe it's time I got a decent carbide up=cut spiral bit for it and learned some decent techniques. v
Thanks for the responses everyone.
o
Pete in Holland, MI
>Won't your mold need some draft to get the chocolates out, or does the chocolate shrink that much? Without adequate shrinkage or draft, you'll end up digging out your chocolates.
Larry in NW Ohio
>You might try www.usplastic.com they have all kinds in the way of plastic. Larry
Edward in Vancouver
>The molds that I have made, and many commercial molds are two-piece. The back is usually metal or plastic with imbedded bits of steel, and the mold has lots of rare-earth magnets imbedded into it. This way a poly sheet can be sandwiched between the two, and there are silk-screened sheets commercialy available imprinted with coutntless designs in coloured cocoa buter.
When properly tempered, dark chocolate will shrink by as much as 2%. Milk and white chocolates less--usually under 1%, because of less cocoa butter content.
Thanks for those commercial tubing sites, I'm starting to get ideas......
