P+C #333 Sander Just Went South
>Good Afternoon Friends,
This one was the best sander I ever owned, and I preferred it over the two Ridgid 5" ROS I also use. My #333 was about 8 years old, and was the first of two I bought. The second stunk. After several P+C Service Center attempts at repair, I threw it out.
Just last week I bought several boxes of Klingspor 5 hole stearate discs. Bummer for sure. Now the dilemma to decide what to do. Replace with another #333 or #334, repair the one I have, which could be nearly as expensive, or buy a competing brand. I assume I could use the 5 hole discs outdoors with any hole pattern sander. I do most of my sanding outdoors anyway, and would use the Ridgid w/vacuum in the shop if need be.
So far, I've trash tossed 5 inch DeWalt, P+C, and Bosch ROS's, and am disinterested in makijg the same mistake again. Anybody have thoughts on the Milwaukee? I can't afford a home mortgage and a Festool simultaneously, and SWMBO has opted for the mortgage.
George
Re: P+C #333 Sander Just Went South
How I solved this issue *LINK*
Bricofleur
>Good afternoon George,
Check out how I solved the issue of choosing a ROS. You may like it.
I'll let you guess what happened since I shoot this picture!
Best,
Serge
www.atelierdubricoleur.spaces.live.com
The Glamour of Sanding
Jim Dillon
>Hi George,
Since you just bought a quantity of 5-hole sandpaper, and you have several backup Rigid ROS sanders, I would just take my time and shop for the best price on a PC 333/334. My 2 cents.
I have had good luck with my 10 year old PC 333, although I have had to replace both the belt, and the hook and loop pad, but I consider that normal wear and tear.
Jim
>You did not say what went South. I have two of them and have repaired the older one twice I think. I replaced the bearing and the belt and have replaced the pads several times. I really like mine and especially like the fact that i can connect a 1" (?) round hose to it. When It crapped out on me and I had to wait for the bearings, I bought a second one to cover the time. That one turned out to be a 334 and it had an oval port. Not to my liking, so I took it back and mad them give me the 333 off the display. (Someone has since told me the oval port comes off and you can use the round port, but I don't know that.
The newer version that is low profile looks interesting, but more expensive. I like my older ones well enough that I would fix them before buying a new one, even if the cost were about the same.
Larry in NW Ohio
>Colonel What went wrong with your sander? Larry
Chuck in ND
>George, I have done alot of sanding, alot of the furniture in our home are antiques that I have repaired and refinished over the years. I have 2 DeWalt palm grip orbitals, the oldest one that I have used the most takes sticky back paper with no dust collection, I have replaced the pad and the brushes on it after many years of use and it still works like new. The other DeWalt takes hook and loop paper with holes, and ofcourse has dust collection, I haven't used that one as much, but I recently got a pretty good deal on some paper for it, so I'll be useing it a little more. In a nut shell I'm vey happy with both Dewalt orbitals. I do have a Poter Cable 330 Speed-Bloc 1/4 sheet sander that I would recommend to anyone that needs to sand inside corners, it works excellent with the sticky back paper. I know it isn't a orbital sander, but I just thought I'd throw it in since we are on the subject of palm grip sanders.
Its The Best Horse in the Stable
>Good Evening Chuck,
I have a Speed Block #330. Best investment I've ever made in sanding.
George
What Went Wrong
>Good Evening Barry and Larry,
Sorry for not telling! I chastize myself unmercifully over that fox paw. I'm not sure what went wrong. The switch is in the "on" mode. As I used it yesterday, I turned it off to shop brush the dust off before switching to a finer grit. When I tried to start it up again, it was dead. The "off"position in the switch feels clogged because the switch won't travel as before. So I suspect the switch. My eyes aren't good enough anymore to open up the machine and see anything, and #3 son is away at his summer home. If I haul it to the P+C repair center, I will have a complete overhaul done on it. I'm just not so sure if a tool that old is worth the effort, considering how many have failed. OTOH, this one was one of the best I've ever owned, and was my preferred sander.
George
Try blowing the switch out
Phil Joines Krum,Tx
>I do maintenance at an aircraft cabinet shop. It's incredible how many tools stop because of dust in the switch.
switch bad
del schisler
>the switch you said doesn't travel like it did? their are a few pieces inside of the switch probly the little spring iside that is in a little hole on the switch arm that move on the little brass piece inside that move's it to the contact's inside Just order a switch probly 2 wires on it If you can just get a outside switch of some kind and wire it on the line cord outside Of course that won't be handy but may be a cheep fix? You could have to go inside and jump a wire over the switch Like it would be on all the time and just plug and unplug the sander Cheeper yet my 2 cents
Re: Its The Best Horse in the Stable
Larry in NW Ohio
>Colonel If you would want to, you could ship it to me and I`d be glad to take a look at it. It sounds like just a switch, like everyone else says, I don`t think it would cost anymore than $10 to ship it. My cost wouldn`t be much if anything, being a fellow military guy, I try to do what I can for people that served our country. I may not be the best but I`m cheap. Larry
Kind Offer, Larry
>Good Afternoon Larry,
I'll take it over to #3 son's shop. Ken has a couple of strong compressors and we'll try to blow the switch out. If that doesn't work we'll examine the insides carefully and try to determine the actual problem. I appreciate your offer.
George
Re: Kind Offer, Larry
Larry in NW Ohio
>Any time Colonel.Offer always stands. Larry
Michael Wilkins
>I have had that same sander for nearly 20 years. Only thing replaced so far is the pads. PC recently came out with the low-profile RO sander which is supposed to be a great improvement over the old one.
Only problem is this; it uses 8-hole paper, not the current 5.
This would be a bummer if, like me, you have a nice collection of 5 hole paper already. If mine ever goes south, I would just bite the bullet and get a new one. May not be worth the repair.
