OT Digital Cable router question?
>A friend of mine was having trouble with their cable modem/router. (I just realized I don't even know exactly what the gadget is, router, modem what ever.) The cable keeps going out and they don't have Internet service. The company (Comcast I think) has serviced it several times, but it keeps going out. One of their over the phone people told them to move the device away from the speakers on the computer because the "magnets" in the speakers would interfere with it working. They moved it about ten feet by rearranging the wires and things may be a little better, but I think it has gone out again anyway. Make any sense?
Re: OT Digital Cable router question?
Larry in NW Ohio
>Barry For what little I know about computers, a router, unlike the one in our shops, is a device that is hooked to a main computer in the house, and sends all the information to various computer equipment thru the air and not wires. So you go wireless. Maybe someone else can explain it better. I`m affraid I can`t help your friend with his problem other than to uplug your router cable and plug for a minute or so and then plug it back in and restart. Good luck Larry
Lee Schierer - McKean, PA
>It sounds like hocus pocus to me. Most electronic circuits are not affected by magnets, otherwise how would a cell phone, walkman or other device work? Comcast has a reputation for service outages in the area where my daughter lives (southern NJ), so it wouldn't suprise me to hear they have the same problem in other areas. Our telphone DSL modem sometimes gets confused (maybe once in 9-12 months or so) and doing a cold startup has always fixed the problem. We simply turn it off for 10 seconds and then turn it back on.
Lee
Bill Howatt
>A router can be wired or wireless or both. It does not have the same capability that a real router in a major network (they actually do route (allow/disallow) traffic to sub-nets). The home router is probably better called a gateway (to the internet) combined with an ethernet switch if able to handle more than one computer. A box that functions as a gateway to the internet but only supports a single computer is usually referred to as an Access Point but terms vary.
The magnetic field from speakers issue is nonsense. These problems are difficult to pin down because of the variables ranging form the provider's problems such as with servers, cable equipment problems from the server to the house including the modem/router, the PC hardware, the programs/configuration on the PC, etc.
One problem, I had with a dial-up modem, was losing the connection regularly before supper. Appears the problem was sensitivity to line-voltage noise or fluctuations cause by the electric stove elements cycling on/off. Changing the modem for another identical one fixed the problem.
I have DSL service and about once per month the wireless part fails but the wired connections are OK. A reset by pulling the router's power plug for 10S or so fixes it.
Bill
David Hammelef
>I think the speaker thing was a hope.
I will try to give a another definition.
Modem -- Connects to the wall (use to be phone line now might be your cable) takes incoming signal from provider (and may include a firewall to stop bad people from getting in ) and sends it to your computer or router if you have one.
Router -- Allows multiple computers to connect together and share 1 modem for internet access.
currently lots of providers give you a modem with a built in router only to confuse the issue,
Bill White
>How different is that from a Porter Cable router?
Sorry! Just couldn't help it.
Bill
Jerry White
>I have internet service through Comcast and am connected through a digital modem and a router. Almost every time that we experience a momentary interruption of our electrical power from the power company, I have to unplug the modem and router from AC power for about 30 seconds to allow them to restart. Could this possibly be a cause to your friend's problem?
Dan Donaldson
>The PC is defective because they forgot to put in the plug for the cat 5. ;-)
Dale Lenz
Dale Lenz
>Actually...I open up this thread to see what the new router in town was about, digital cable router, oh well.
