OT - Hose valves and freezing
Jay St. Peter - Southern, MD
>For the third time in 6 years I've cracked the hose valve on one side of my house. It is in the closet I keep my cyclone, which is insulated for sound so it stays colder in the winter. But, the real issue is that it is the closest hose to the driveway. So I take advantage of nicer winter days to get the crud off the cars and forget to turn it back off.
I use the longer hose valves that crack and don't leak until you turn them on. They don't make a big mess, but it's still a pain. Before I go solder another on, is there a better solution? If not, maybe some ideas to make it easier to replace every couple years. I have to get into a pretty tight area to do the soldering with plenty of insulation around.
TIA,
Jay
