Best way to cut skinny sticks?
Doug in Denver
>If I want to cut pieces maybe 24" long, but only 1/16" X 1/16" (basically like a long wooden match stick)is there a better way to do it than on table saw using a zero clearance plate? I know when you try and cut something that thin you get a lot of chatter and it can be hard to get it past the blade without it geting chewed up. Is there a better way?
Re: Best way to cut skinny sticks?
>I would take 24" long pieces of say...4/4 stock and rip it on the table saw with a 1/16" waste. Then take that waste piece and cut the other 1/16" dimension with a straight edge and an exacto knife.
Tom
Lee Schierer - McKean, PA
>First I would make strips of stock several inches wide to the thickness and length needed. Then I would rabbet the edge of a board about 4-6" wide with a rabbet the size (height and width) of the stick I needed. Glue a strip of wood across the end of the rabbet that will be toward you. I would place the rabbet down and toward the blade and adjust my fence so the edge of my board was just touching the blade. Then using a feather board to hold the thin stock into the rabbet and another to hold the larger board tight to the table. Stick the thin stock in the rabbet, put the feather boad against it, start the saw and push the rabbeted board past the blade, pulling the thin stock with it. At the end of each cut, turn off the saw and adjust the thin stock feather board closer to the side of the rabbeted board and repeat the process.
Lee
Did it many times with this push stick *LINK*
Bricofleur
>Lee,
Simple and safe to do it with this shopmade push stick. As titled, many times I made tiny moldings without any problem.
First, you need a zero clearance throat plate.
Then make yourself the push stick shown on the picture using 3/4" MDF, higher then your rip fence and as long as your stock (or almost). Screw a backer block to hook the stock to be fed (so it could be changed if needed). A tablesaw splitter is a must here. If you don't have one, make one (link below).
Rip 1/16" strips using this push stick. The push stick will keep the stock on the tablesaw (with your help of course) and you'll be able to feed into the blade safely. Raise the saw blade only to cut the strips, not the push stick (or only a little).
Now lower your saw blade to cut the strips to the appropriate 1/16" width, again using this push stick.
Are you comfortable with that?
Best,
Serge
PS: I made mine comfortable by sanding over the upper back corner.
www.atelierdubricoleur.spaces.live.com
Shopmade Splitters
Blade specs?
Ellis Walentine, Host
>Serge, what kind of saw blade are you using for such thin stock?
Re: Any reason NOT to use a bandsaw?
Glenn Madsen near San Francisco
Doug in Denver
>None other than I'd like smooth cuts, and a bandsaw isn't quite smooth.
Re: Blade specs?
Bricofleur
>I used a crosscut 40T carbide blade but got better results with a 80T carbide blade (finer cuts). Between you and me, a 40T crosscut blade is okay if you don't push the stock too hard or too fast. Again, the key is the zero clearance throat plate, and the push stick.
Best,
Serge
Robin Corell in Atascadero CA
>that is how I have done it in the past and I use a plane to true up the edge between each cut with the knife.
Robin
>Well, you're not likely to get really smooth cuts with most table saws at that stock thickness. Too much vibration and not enough surface to register and hold the stock.
The right band saw and blade would be all right. If you want SMOOTH then a sander is likely in your future. A drum or wide belt sander.
Fine tooth blades
>Whether bandsawing or tablesawing, I try to observe the conventional wisdom about number of teeth in the cut; there is always an optimal number. Too many and the teeth clog; too few and you get tearing and vibration. With 1/16" stock, no circular saw blade will give you more than one tooth in the cut, so feed speed is important -- too fast and the cut quality will be bad.
Years ago, I had a drawer full of vintage circular saw blades -- steel, not carbide-tipped -- that my father had accumulated over the years. For ripping thin stock, I usually trotted out one of his fine tooth crosscut blades or another style of blade designed for plastic laminates. Both had lots of teeth, maybe 6 or 8 teeth per inch of perimeter, and they did a very nice job on the thin stuff.
I think they make tiny modelmaker's saws that are designed for just this type of small-scale work. The closest I ever got was an old Dunlap 8" tablesaw that we kept around for the little jobs, and it worked fine.
Everyone's Missed The Obvious
David Yoho
>I'm surprised this method hasn't been suggested. Not only is it super safe, it doesn't require the cut-off be between the blade and fence. The small cut-off falls on the left of the blade in my method.
When I need to make matchstick-sized pegs to hide finish nail heads, I start with a piece of 3/4" stock the length needed and whatever width I have cut it (usually about 3-4"). This method can yield up to four 1/8" by 1/8" strips before ripping the edges and starting again. I use a zero clearance insert, set the blade height to 1/8", and set the fence to take into account the blade width and the amount I want the cut-off to be (in this case - 1/16"). Make some test cuts and adjust where necessary.
First, set the fence so there's (in this case) 1/16" left between the edge of the stock and the saw kerf and run the stock against the fence on both face edges and flip it and repeat. Without changing the height of the blade, re-adjust the fence so the stock can be cut on its edge and leave the 1/16" cut-off.
That's it. Simple, safe, and pretty accurate. Try it - it works!
David
ripping with a cross cut blade?
Bill Tindall, E.TN
>Isn't this operation dangerous? Well not on something 1/16" thick but the first cut is from thick stock to make the 1/16" strips. I have always heard, and have some experience, that a cross cut tooth pattern is more apt to bind and throw things if used for ripping.
BTW, I use a very narrow kerf 40 or 52 tooth 7/12" combination blade for these thin strip operations. The tiny teeth don't hammer the thin pieces and get them to vibrating which can lead to thin stuff shattering during the cut.
Only for the thin stock
>Right, Bill. You and I are thinking very much alike. Use a regular ripping blade to part the initial strips and the fine tooth blade to rip the final stringing (if that's what we want to call it). I actually liked my laminate blade for the little string cuts because it didn't have a set to the teeth -- it was more like hollow ground. The effect was like a ripping blade. But, crosscut teeth don't have any particular disadvantage in stock that thin.
Re: Only for the thin stock
Bricofleur
>Obviously, you're right. The first ripping operation on the thick stock should be done with a regular ripping blade and only the 1/16" thick strips to be done with the crosscut blade. I believe when writing the entry my mind was stuck on the "thin" part.
I agree with Ellis about using a laminate blade, but only on the 1/16" thick strips. I checked mine and it has 10 teeth per inch and makes a kerf less than a 1/16"-wide. Since those tiny teeth are not carbide, the blade getting dull fast could be an issue though. By the way, I bought it at Sears in the '70s.
Best,
Serge
