Re: Workshop Building- need help!
Charlie Self
>I built my shop as a pole building, just shy of 15 years ago. What I got: 1200 SF, 9' ceiling (a mistake, go for 10'), insulated, free electric furnace (from a throwaway pile: it lasted about two winters in light use), 200 amp box, plywood floor, PT floor framing, rough SYP wall and roof and ceiling framing. Board and batten mixed rough lumber for siding, built both doors myself, including a double 4' wide set on barn door sliders--another mistake. Interior is 7/16" OSB, which is actually about four bucks a sheet cheaper now than it was then.
My wife and I did the work, except for roof framing and tin installation on roof--I wouldn't use tin again, either. Nostalgia for old VA Piedmont tin roofed farmouses bit me. It's hard as the devil to seal against birds.
Nothing fancy. I forget how many 120 volt 20 amp circits, but I think 7, with two 15 amp lighting circuits. Five 240 volt 30 amp circuits. 120 volt outlets every 4', another mistake. Two feet makes mroe sense, leapfrogging the circuits. I did the leapfrogging.
It cost me about $11,000, not counting the free floor plywood (my wife gave it to me as a Christmas present one year). That would have added a bit over a grand, 3/4" t&g. Nails were just about free as I was testing tools back then and pneumatic nailers fit into the mix.
I bartered for the roof and roof framing work, so there was no cost there.
Problem: ceiling is a bit low. I used rafters, so there's a post every 16' inside (shop is 48' long). Circuitry as described. Lighting is 20 double 4' fluorescents, with a row of incandescents up the center (8 lights) for those cold days when the fluors don't want to work until the joint warms up. Parts of two circuits in eight outdoor 20 amp outlets.
Oh. I set the poles so that the large door is at the proper height for a standard pick up to back right to it. It works great for tool removal and loading...unless you have things like a 750 pound 24" bandsaw, similar fun stuff. That takes help, but back in those days, anything up to about 500 or 550 pounds could be walked off the truck. Not now. I'm too old and fat to move much more than 350 pounds in one package.
Use square posts. Old telephone poles are cheap, sometimes free, but they're a bitch to plumb on two or more sides.
