We value your privacy.
>We`re redoing our utility room and we are having one cabinent built and one I`m going to redo. On the redo, the cabinent is in very good shape but the finish needs to be redone. It is 30 years old and has a lacquer finish on it. How would I go about doing this, can I just sand it down say with 100-150 grit sandpaper and then put a poly finish on it, it`s going to stay the same color. Do you think this would work OK? Thank You Larry in Ohio
>Eh Gods ! Sanding that might turn into a lifetime project. I found the "L's" home brand stripper safe and fast. Then even everything out with # 220 paper. Good luck !
>What I hoped to do was just give it a light sanding ti try to get the top coating off and kind of clean it up a little. Then put some stain and put the poly on. This is just a small cabinent about 31X32 and only 2msides will show, front and left side. I was just hopeing what I want to do would be good enough, do you think it`ll work OK Thanks Larry
>I don't think your approach will work for one main reason. You'll need to sand through the topcoat (lacquer ?) and into the wood a bit to open up fresh wood cells that will accept your new stain. Just getting the surface topcoat removed won't guarantee success.
You really have two choices - strip it and start new, or sand it, apply some de-waxed shellac, and finish with your choice of topcoat. The "sand it" method would only require sanding the old topcoat until it is smooth. The shellac will stick to your old topcoat and provide the new topcoat with something to hold on to, as well.
