THE WOODRAT IS BACK!
Must be something going around
Larry in NW Ohio
>We redid our utility room this week and when I put the cloths washer back in anran it, it started leaking. Oh CRAP. Well it wasn`t to bad, so left my wife do some laundry while I cleaned and picked up tools and things. Well whenshe was done I took the front off and saw what looked like grease splattered around inside. So I`m assuming the tranny sprung a leak under the drum, hence the water and grease. What would some of you think is the problem? I can`t really tell where the water is coming from as of yet, I`m tired. So I thought I`d wait till tommorow to run it wiyh the front off to see where the water is coming from. I was hoping to do some sandblasting tommorow, oh well the story of my life.TIA Larry in Ohio
Re: Must be something going around
Dick Coers
>I had my washer apart last year to replace the seals between the drum and shaft. It was a BIG JOB! Left hand threads, odd spanner nuts, etc....You probably have a grease seal out on the gearbox as well. How about excess noise? If a bearing is going out, it may be letting the shaft move around too much and wore out the seals. I'll not do it again to my machine. I wasn't sure it would run again when I was working on it.
