Sandblasting sand
Sandblasting sand
Sandblasting sand
Larry in NW Ohio
>I want to try blasting some wood once. I`ve heard of people doing it for a different effect, but never tried it. The problem is I can find any sand, so does anyone have a little sand I could buy. I`ll be glad to pay shipping and of course for the sand. I only need about a half gallon to a gallon to ry it. Thanks Larry in Ohio
Re: Sandblasting sand
Gene Gauss
>I buy silica sandblast sand from an auto body supply store near me. It comes in 100 lb. bags, and is so cheap and heavy and you'll use it in such quantities, even for a test, that it wouldn't be economical to pay for shipping a usable quantity. I think I also saw it in a Tractor Supply Co. store near me also. I use one of those cheap siphon type sandblaster that you just stick into a bucket of sand, or even just into the bag.
No sand in Ohio?
>How do they build concrete foundations, highways, and sidewalks in Ohio? Are children forced to build mud castles in the mud boxes in the park?
Seriously though...... besides water, isn't sand the most plentiful thing on the earth?
Although sandblasting can involve exotic types of "sand" including crushed walnut shells, specially formulated silica stuff, etc. for what you're describing plain old sand should work fine. I've got an inexpensive sand blaster gun and just use regual old sand in it. Works fine.
You should be able to buy a 50 pound band of sand for a couple of dollars at any HD in their concrete materials area. Or any HD, Walmart or ToysRus will send sand for kiddies' sandboxes for a few dollars more. You can buy the exotic stuff at Northern Tool and some automtive supply stores.
Oh, and you'll us a whole lot more sand than you think. Unless you recycle it. Also, this isn't something I'd want to do inside... it's very messy.
Happy Woodworking!
>I buy play sand at Lowes or HD and sift it through window screen. Works fine.
Clint
Gene Gauss
>And one more thing - Mark alluded to it - sandblasting should be done outside with a good dust mask, and tightly fitting clothing. It brings to mind the old Marilyn Monroe line about why she didn't like to make love on the beach: ".... because sand gets into everything".
Ronald from NW Ohio------WebKitFormBoundaryAAddAAU
>Larry, Play ground sand at Walmart works great!
Chuck in ND
>Black slag is probably available at TSC, or any other stores that sell sand blasters. The reason I mention black slag is it fairly cheap, has sharp edges, and cuts faster, walnut shells would probably be just as effective on wood, but I haven't run across any to know the price.
Karen
>Also check with any equipment rental stores in your area.
I can get it at RSC for cheap.
Larry in NW Ohio
>Thanks everyone, I didn`t know about regular sand. I thought you had to use the silica so it would cut. One thing though, I was also going to sandblast my lawnmower deck while I was at it. I blasted before about 20 years ago. Had an old LUV truck. I was about afraid to blast the rust off because that was all that was holding togeghter, so I`m really not new to this. Thanks for all the suggestions. We have a TSC pretty close and I could check our auto supply stores we have also. Thanks again. I knew this was the place to ask. Larry in Ohio
Re: Sandblasting sand *LINK*
Tom MacGregor
>This link takes you to descriptions of most of the available types of blast media. The corn cob sounds like it might be good for cleaning up vintage tools & machinery without damaging finishes & surfaces.
http://www.kramerindustriesonline.com/blasting-media.htm
Re: Sandblasting sand "black beauty"
jacomb
>we do alot of sand blasting at work. Try "black beauty" which is slag. I can get it at any decent lumber yard, yes we still have those! be very carfull around any silaca product very harmfull to your lungs.
