OT: Water filters
OT: Water filters
OT: Water filters
Dan Mitchell
>Since I got so many helpful, informative replies to my low-flow toilet post, I thought I'd ask if anyone here has any thoughts on another plumbing item I'm thinking of adding, a really effective water filter for the main drinking & cooking water tap in the kitchen. I'm sure the city-supplied water here meets some minimal standard, but it tastes pretty bad. And leave a glass of it sit for a few hours (like on the night stand, for example) and take a sip & it REALLY tastes bad.
So I'd like to add some filtering. Any suggestions?
TIA
Dan
Re: OT: Water filters
Jesper, Denmark
Jesper, Denmark
>Before you do anything, find out why it tastes bad.
Most places that sell water softeners will have some sort of testing/analysis service, either in-store or by sending a sample away for analysis.
The city water department probably will also be able to give you an analysis of their water if you ask.
Filters will remove particles, but not any dissolved compounds, so it is important to know what it is you need to remove from the water.
Howard Norman
>As Jesper said find out why the water tastes bad. I think by law all municipal water sources have to report the impurities in their water on some sort of regular basis. Check with your water department first. The water tests that water softener dealers use is pretty minimal. I doubt that it is going to be very informative in this case. IMHO the best solution to drinking water is to install a RO, reverse osmosis, system at the kitchen sink for drinking water. The unit will cost you a couple hundred dollars and then installation costs if you can't do it yourself.
Curly Smith
>I've used a Midi-Classic distillation unit for the past 10 years to treat my rather brackish well water. As others have said, you need to get your water tested to determine what purification methods are appropriate. In my case, the TDS exceeded the limits for a reverse osmosis system which limited my options. The unit works well with very little maintenance, I just periodically change the pre/post filters and drain/clean the distillation tank.
steve mackay
>Dad put a dual canister rig under the sink years ago and they LOVE it ! Don't know the brand though. I think they got it at your (up-north) Menards (?). I know he did it himself so it must be a "do-it-yourself" rig.
Re: OT: What part of the country are you in?
Gary Camp, Bend, Oregon
>Do you know what type of water system you are on? All Public water systems are governed by the Safe Drinking Water Act. That requires that water systems publish a "fact sheet" yearly. By contacting you drinking water provider they should be able to provide you with all the documentation you could ever want about the water that is supplied to your meter, they should also be willing to help you overcome any taste or odor problems and make recomendations for devices that have help other people in your community. I can't imagine any drinking water professional who wants to provide anything but the best tasting water possible. Now if the problem originates for your household plumbing they will still probably help try to solve the problem. Taste and odor problems are the most difficult to solve, because taste is sbujective. The other option (although not a good one) is to move to a part of the country with good drinking water ;-)
glc
Good luck
What was the original topic?
Marv....... Northern California Lake Co.
>Everytime I see OT in here, I always wonder, what was the topic that the poster is off of?
Isn't this forum meant for any and all topics?
Just curious..
Marv
Re: What was the original topic? Wood!
>This is Wood Central. The topic is WOOD. Making furniture and related products is central to Wood Central. Wood working associated with houses is only slightly OT.
Bob Lemon, Sacramento CA
>Q: What are all the WoodCentral messageboards about? What kinds of messages should I post on which boards?
A: We have nine different messageboards with distinctly different themes:
* Messages - our main board where you can post messages on all topics.
* Hand Tools - a place to discuss hand tools and methods.
* Turning - our forum for turning and related topics. There are many excellent turners that frequent this board and they are happy to answer any questions that you may have.
* Carving-This board is dedicated to questions/discussions concerning woodcarving in all of its forms.
Dan Mitchell
>Thanks for the replies. The local water district (Edmonds, WA, just north of Seattle) does provide an annual report, of course reflecting that the water supplied is "within accepted specifications". It's probably worth a call to at least get their response on the taste issue.
Reverse osmosis is one approach I had considered, but I agree an independent analysis may be the best 1st step.
Dan
Dan Mitchell
>So, not water filters?
Or, say, HDTV?
I think you see a fair number of OT posts here because there is a lot of expertise to tap into, expertise which is for the most part quite generously shared. I certainly try to reciprocate whenever I can, and I think most others here do as well.
If someone sees a subject, "OT" or otherwise, which is of no interest to them, I suggest they do what I do in such cases - don't read it.
Dan
>As often is the case, my point was totally missed....
If this is an open forum, and it appears that it is, why preface so many post with OT when there is no specific topic to start with.
Yes, this is Woodcentral, that offers an open forum.
Now if you are in the Hand Tools message board, for example, OT is quite appropriate.
Hey, just wondering...
Marv
>I personally like the OT posts and post some of them myself. There is a huge body of knowledge here and I really enjoy taping into that base. I also try to contribute to that when I can. But, having said that, there are some here that would prefer we stick to the topic (Wood and things closely related to wood working.) So, for their benefit many of us put the OT in the subject line. This is a great and generous group and we thank Ellis for making it possible and riding herd on it. (My previous Internet group experience was not so good. Lots of flaming and really ugly commentary. I did not stay long and I am glad this place turned my view around.)
steve mackay
>I also gain from the "OTs". After hanging around WC for awhile I was blown away by the diversity of profesions and interests. I tell friends about the MIT Profesors and NASA engineers that go home at night and work with Victorian Age tools to "get away" !
Larry in NW Ohio
>I for one really enjoy this forum, as a matter of fact this is the only one I go to. I tried a few others and they were so crude that I soon left. Tell me where else can a person go and ask about any question you may have, from fixing a washer to a water heater and once in awhile someone has a question about woodworking, but really where else can you go and have the knowledge we can tap into. I don`t think anywhere. For one I thank Ellis and all his helpers, I just wish I could help in some way other than to give him some money every year. ELLIS THANK YOU AND YOUR HELPERS. Larry in Ohio
