Theatre shop equipment suggestions?
>I've been asked to compile a wish list for new (or used) shop equipment for the community playhouse. This will be used to build sets. I've talked with the new theatre manager about the Sawstop contractors saw - but as we are a community organization and get money by begging (grants, donations, etc.) - I don't know if that will fly.
Anyway, I've come up with the following list.
Contractors saw - Sawstop if we can swing it, or else a new or quality used one.
Compound miter saw - 12" or a 10" slider
Cordless Drill/drivers - preferably 2
Corded drill - 1/2", preferably a hammer drill
Circular saw - old one is old
Jig saw
Clamp guide 50" and 99"
Clamps (C clamps, bar clamps, spring clamps)
Hand tools of various sorts (vise grips, wrenches, screwdrivers, etc.)
I am somewhat uncertain about requesting a band saw and a drill press. I can see the need for both sometimes, but usually we are not cutting things that really need a band saw. We sometimes do a lot of repetitive drilling - but not as a matter of course.
Primarily we work with lauan (1/4" or less) and 1 x 3s to build the flats. The platforms are 2 x 4s and either 5/8" or 3/4" plywood. The rest is tape and paint.
So - can anyone think of anything else? Do you think a benchtop drill press or a floor drill press is a good idea? How about a band saw?
TIA
Re: Theatre shop equipment suggestions?
Nail guns
Mac in Indy
>I've helped at the high school plays for years and couldn't imagine doing it without nailguns. I use the 1/4 crown stapler to mount the luan to the 1x frames. Trim nailer for odds and ends. The Framing nailer for major builds like raised floors.
I think a hand saw is handy but I'm old school. And I prefer corded drills for driving lots of screws.
I always had lot's of fun with the kids, helping them learn to build things. My last one enters HS next year so I'll be signed up for another 4 year run!
Mac
Re: Nail guns
Larry in NW Ohio
>I built sets for our community theater back in about 1996. I built all the sets at my house since they did`t have anything and didn`t have anything to get something with so I used all my tools. Even at that I had a great time and would do it over. One thing you may want to get are the 11sp and get quite a few of them, they are the handyest things to have for clamping temporary sets together. The best place I found to but them is Enco at use-enco.com they have them on sale about all the time and they are great to deal with. Good luck and break a leg. Larry in Ohio
Bill Hammond, Oregon Coast
>I have worked and ran several theatre shops. The table saw should be your last purchase. For most scenery it has little use, can be very dangerous for people who don't know how to use them and it takes up a lot of room, I would also avoid the radial arm saw for safety reasons too. Skill saws and guides are better and safer. A router trims lauan for flats after it's on, no need to cut it first.
I would get several miter saws, used ones that are not compound or slider cut 1x3 and 1x4 just fine and 10" blades are far less expensive to buy than 12". Save the compound slider for the prop shop. Same with the bandsaw and drill press. Props has more use for them, assuming you are building props. I would also get screw shooters, and air staplers and nail guns. Invest in a good high volume air compressor, it will serve both the shop and scene painters. Don't forget the cheap spray guns and a oil trap for the air line.
In addition one or two good jig saws, Bosh, will replace the bandsaw for the most part and a sawsall for strike. While cordless tools are handy make sure they all take the same battery, You will need at least one 1/2" corded drill.
Invest in good hammers like Estwing and screwdrivers that are not junk. Nut drivers and a socket set and other hand tool. Framing squares, combo squares and tape measures. Lots of tape measures they get lost in the shop very fast and you probably only need the inexpensive 12' ones for the most part.
If your theater has a flyloft and you will be flying scenery I highly recommended Nicropress sleves and a Nicropress crimping tool. If you use the sleves you have to crimp them properly with the tool. This will make cabling very simple and safe. Get the set for 1/16 and 1/8" aircraft cable.
Roto-locks work well for holding platform and scenery together when quick release is necessary for scene changes.
Don't forget safety, while many will show up with their own tools no one will bring a first aid kit and few will bring goggles and face masks.
Remember to think of who will be using the tools, their capabilities and the group stupidity factor when selecting the tools. Think too of how many will be working at one time, you have to have enough tools for everyone, a volunteer who waits for a tool to do a job likely will not come back. If you have an older group you will need work tables, if it's kids or youths they will happily work on the floor.
I wish you good fortunate in setting up and running your scene shop.
Bill
forgot something
>See if you can score a used industrial sewing machine for the shop. Use it to sew up drops and curtains. Seamless is very expensive and often muslin can be used. It will also do for upholstery and heavy stuff in the costume shop.
bill
Where's Forrest Addy?
Rod Peterson -- Ormond Beach
>This question is right up his alley.
Rod
Addy Protocol: I am not Forrest
Track Saws
>Rather than a table saw you might consider a track saw. Basically a circular saw with a track guide. I have a Festool that I love. But DeWalt makes a good one for a little less $$.
Tom
Lee Schierer - McKean, PA
>Instead of a band saw consider a Bosch jig saw. It will cut material up to 2" without a problem and it can cut curves. You can also do very straight cuts with an edge guide.
Pocket hole screws also work very well for set frames.
Lee
You forgot an air compressor
>How else are you going to inflate the actor's egos without a large air compressor?
Happy Woodworking!
We've got to deflate, not inflate.
>Their egos (even for community theatre types) are already large enough.
Okay then.....
>You would have to go with a non-electric type tool, like an awl ;)
LOL
Happy Woodworking!
Requires thinking..
>a table saw is good for repetition - as in go rip a couple of pieces to a particular width. Also, a track saw isn't that good for ripping long (10-12') pieces of lumber. Though it does work well for plywood.
Good points
>We are the prop/scenery/everything shop. We typically put on 6-7 shows a year. I'll have to see about talking them into a large compressor.
Re: Good points
Bill Turpin in WNC mountains
>A � waist high STURDY table that is a few inches larger than a 4' x 8' sheet of plywood. This is wonderful for saving your back while making flats and platforms.
