Cabinent redo
Cabinent redo
Cabinent redo
Larry in NW Ohio
>I`m redoing a couple of cabinents that were in the house when we built it back in 1980. The finish is laquor(sic) and I`m wondering can I put poloy on top of it without any problems or what would it do to one or the other. Thank You Larry in Ohio
Re: Cabinent redo
Re: Cabinent redo
Lee Schierer - McKean, PA
>I've put poly over lacquer without a problem. If the cabinets have been in or near a kitchen make sure the surface is clean of grease. Water based poly may just bead up on the lacquer. I recommend lightly sanding the surface.
Lee
