Unisaw Withdrawal Update
Ken Oakley-Sunny St. Cloud, Fla.
>This morning, braving the frigid temperature,(42 degrees),I went out into my shop. I loosened the bracket bolt on the motor, jacked up the motor and removed the 3 drive belts from the motor to the arbor. Pushed the start button and the motor instantly started purring like a kitten. Eureka!!. Then I tried to turn the arbor and it grudgingly turned, but with noise and resistance. So now the problem changed complexion.
I tried calling the Delta/Porter Cable center in Tampa, but the number I had was from literature I received with the saw. Number no longer in service. Went to the Delta website and found a listing of Authorized Sevice Centers and found one located in Orlando. Called them and spoke to the technician that does that repair and he told me the differance between me removing the arbor and bringing to the center and him doing the repair at my shop was about $50.00. So Wednesday at 10AM he will be here and by noon I will be happily cutting wood again. Somedays it just pays to get out of bed. Besides I will save the differance between the cost of a new motor, tobaco, booze, and Prozac. Life is good.
Re: Unisaw Withdrawal Update
Dale Lenz
Re: Glad to hear, : " >
Dale Lenz
paul waddle
>I hope your problem is solved. BUTT, the bad bearings could have smoked the motor. When the belts were on,you couldn't really tell.pw
Larry in NW Ohio
>You said you had smoke before you shut it off, it`s very possible the belts slipped and smoked, I hope that is all. But that would be my guess, because if the motor stalled I think it would have overheated and popped the breaker or the heater in the motor. Best of luck. Larry in Ohio
But
>It now a bit less than 48 hours 'till your "fix" arrives. Whatever are you gonna do in the mean time?
Saving $$$? I could go through a fair load of hooch, smoke, and Prozies in that amount of time.
I would get a new set of belts while it is dead.
Ken Garlock, Collin County Texas
>I am getting new belts. I have started motor 3 differant times today letting it run as long as 15 minutes and no overheating detected and purring rioght along. No matter, it needs bearings and if a problem does arise with the motor, then I will have to replace that
>My younger son's got an old Unisaw - the giant motor, saw probably from the early 1950's - that's had rumbly bearings from the time he paid $50 for it at the dump - still running...
I've almost forgiven him for finding it instead of me finding it.
Congrats on the unisaw! Good call Chuck!
Bob Entwisle in NJ
Larry in NW Ohio
>Ken I don`t think your going to have trouble with your motor, I think you just smoked your belts. I`m happy for you. Larry in Ohio
Re: Thankyou Bob
Chuck in ND
