We value your privacy.
>I have a Black & Decker Sawcat circular saw. Must be at least thirty year old. The label is gone off it. (From the days they decided stick on labels were good enough, but I think it is a 3037-09.) The shaft is worn where the blade mounts. I am guessing that an abrasive blade spun on the shaft and ground it down to the point the shift is several hundreth's under size and the blade might not center up. I have searched the tool repair sites and it appears parts are not available.
Really don't have the bucks for a new saw right now. This was a good saw in its day and I don't want to replace it with a cheap one. What are the chances I could do something like coat the shaft with epoxy or JB Weld and file it down and make a serviceable repair? Any other suggestions?
>Depending on the specific wear and if there is room for a heat sink of some sort, I might try adding steel by tack welding then file round. Have to be real careful not to warp the shaft.
I'd be afraid JB Weld wouldn't hold up - it's basically iron filings in epoxy - but it wouldn't hurt anything to try. I've used it to make a lot things and lots of repairs. (I buy the industrial size!)
I retired mine a couple years ago after 30+ years of noble service. It was still running strong, but the guard was jamming and the lever was falling off.
Epoxy alone seems like a doubtful fix. You might try turning a washer out of some brass shim-stock of the appropriate thickness, then epoxy that to the arbor.
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
Guest
If there are any stained glass shops near,
>You might see if they have some thin copper foil tape. It has adhesive on one side, and can be wound around the shaft. Then the compression between the washers will take care of the rest, after it is centered. ,,,,,,,,,,,,,,,,,, uh, maybe.
>You said: "the shift is several hundreth's under size and the blade might not center up"
You sound as if you have not tried to see how poorly the blade would not center up when your talking hundreth of an inch. Will you really see it at all.
If you knew what the clearance is you could wrap 30 gauge copper wire that is 0.01 diameter around the shaft. Could flow some solder on to hold it.
Larger copper wire ring could be used and compress into the space.
Without seeing the tolerance hard to suggest best wire size.
>Why are you worried about a couple hundred thousandths on a 30 year old circular saw ? It's only a circular saw. And even if you could find a new part, it would probably cost you more than another run of the mill circular saw.
>Chuck, Asked "Why am I worried about a couple hundred thousandths?" Not thousandths, hundredths. It "seems" fairly sloppy. Without the washer and nut in place the blade will slop around what seems like a 1/32" maybe. With the washer on and it bolted up, it seems to run fairly true. But, I don't want this to get worse and kill the saw. Times are tough, and this is what I have. It seems I am working with my tools again and need to earn a living.
Del, I found that site also and by looking through the diagrams I decided this was a 3030-09 Type 2 (probably). The piece I need (no. 16.) is "no longer available".
On the other hand, a similar piece on a different saw was either $64 or $84, (I could not tell if it was a 6 or and 8.) For that kind of money I would buy a new saw. But that new saw would cost more than that. This old beast was the real deal and has served me well for 30+ years and even though my career as a carpenter is coming to an end, whether I like it or not, I would not replace it with a cheapo piece of crap.
Thanks to everybody else that responded with ideas on building up the shaft. I am not much of a metal worker, so there were some ideas I had not thought of. I was wondering if metal workers had some sort of device that welded on a layer of metal that could then be filed down. Some sort of a cross between welding and spray painting? Or perhaps magic?
An interesting this is that the end of the shaft is sort of mushroomed or larger than it was. As if the end bulged. The blade is hard to get on and off. Sort of "snaps" over the end. I may file that a bit.
>Barry I just remembered that in another life when I was still working for someone we sent some thing to a machine shop and they did something called "spray welding" on a shaft to fill in low spots. This was done in spots where say a bearing would be and it wore down the shaft. When it came back it looked pretty much like new and wore very well on some 50HP motors. So you might try that if you can find a metal shop that does it or maybe a High School that may do it. Just a thought and Good Luck with it. Larry in Ohio
>Is anyone else idiotically loyal to your tools? They are like old friends. I can't buy a new one if I can fix the old one. I would have arrange for it to go away, perhaps die or at least retire. Maybe I could give it to some needy sole that would swear they were pleased with it and would take care of it and use it well.
