A55 Smoothing Plane
Automatic fan
Automatic fan
Automatic fan
Lee Schierer - McKean, PA
>Has anyone made an entertainment center with a built in fan? I'm in the process of making one and feel I may need a fan to pull the heat from the cabinet, but don't want the fan to run 24/7. Is there an inexpensive reliable way to automatically turn the fan on when the components are turned on and have it go off when the components get turned off?
Lee
Re: Automatic fan
Re: Automatic fan
Dave Paine
>How about looking for a fan which is temperature controlled, since you are correctly concerned about the heat, you only really need the fan to run at some pre-set temperature. You should be able to find such fans. My PC power supply has a variable speed fan. This is about the size you would need.
Re: Automatic fan
Good idea, and.....
>you are going to want a fan that is really quiet. See if you can find the "Sones" rating on the fan. One disadvantage to having the fan controlled by a thermostat is that it may come and go. If ti is noisy, it will be especially annoying if you have to turn the volume up and down as it comes on and goes off. Cushion the mounts so the whole cabinet doesn't turn into a resonator.
If you wanted to go crazy, you could mount the fan remotely and duct the cabinet to the fan to eliminate the noise. If you putt he fan in the attic or crawl space it might have a significant impact on you energy bills. Even crazier, you could have a summer/winter set up. Duct the heat OUT in summer and IN in winter.
Re: Automatic fan
Re: Automatic fan
>I once installed a fan in a cabinet that contained a computer. I used a 110v whisper-quiet 6" muffin fan from an electrical supply house. I could not hear it run. It used very little current so I ran it all the time.
Re: Automatic fan
Re: Automatic fan
>I had one of those once for distributing heat produced by a solar heater. Might want to think about a filter. Mine created the Dust Bunny that ate Chicago. Worked great and was quiet, just found all the dust in the house.
Re: Automatic fan
Re: Automatic fan
Larry in NW Ohio
>Lee I did the exact same thing about 6 years ago whenI built mine. I thought about it for quite awhile untill I was once in my shop and turned on one of my routers and my shop vac turned on. BINGO I thought you big dummy, it was right in my shop almost staring me in the face. Go to sears and get their Power tool switch #24031. It`s a switch, as I said,it`ll turn on one other device when you turn on the main devices such as your TV and they are only around $20. Good Luck Larry in Ohio
Re: Automatic fan
Re: Automatic fan
Pete in Holland, MI
>Most receivers have a switched outlet on the back. Get a 110v fan and use that.
Re: Automatic fan
Middle Atlantic *LINK*
A Wright
>I installed a temperature controlled exhaust fan in our AV equipment closet that was made by Middle Atlantic (the Duct Cool model), and I have been very happy with it. It turns on at 88 degrees and turns back off at 85 degrees.
They also have options for cabinet style fans that would fit what you are building
http://www.middleatlantic.com/rackac/cooling/qcool.htm#cabcool
Re: Automatic fan
Re: Automatic fan
>I thought of one of those, but didn't know if the TV or amp would draw enough power to turn it on. Now I'll have to find a really quiet 120V fan...
Lee
Re: Automatic fan
Dream On
>I remember the first time I heard "Dream On": I was about 8 years old at a freind's home after school. His older brother had just bought the album "Toys In the Attic" and I was an automatic fan of Aerosmith.
Happy Woodworking!
Re: Automatic fan
Gotta confess
>"Sweet Emotion" and "Walk This Way" were probably the first songs I heard. But "Dream On" was a more eye-catching subject line for the response in this thread.
Happy Woodworking!
Re: Automatic fan
Re: Automatic fan
Rob Hix - King George, VA
>Lee,
I am in the process of building mt Entertainment center and I needed a solution for this too, my cabinet will have 4 fans. I found this litte device online. The price is definately right. I have no idea about reputation or anything, but controlling up to 8 fans caught my attention.
http://www.coolerguys.com/840556086611.html
I hope this helps. If you order one of these, let me know how it works. I am still a few weeks away from the point of getting one.
Rob Hix
Re: Automatic fan
Re: Automatic fan
Joseph Grittani
>Assuming any componentry in the entertainment center would wired into a stereo receiver - my tuner/receiver has a built in switched outlet on the back to which I plug in a very quiet whisper fan - about 6", I think. Every time the receiver is turned on, the fan comes on with it.
Joe in Dayton
Re: Automatic fan
Re: Automatic fan
>I'm getting ready, when time permits, to install a switched outlet in our entertainment center, to eliminate the wattage draw when the DVD, TV, etc. are turned "off." A lot of modern appliances draw a small amount of current at all times, unnecessarily. If you're comfortable with that approach, you could include a fan plugged into the outlet, to turn on whenever you had the entertainment gear on, and accomplish two things at once.
