Re: Is this a safe operation? Several pics.
A.J. Hamler
>Joe...
The way you have it, I wouldn't do it. The way you have the tape on the shim on one side only, the box can be opened like a book. Once you cut all the way through, it would "flap" open as you finish the cut.
It's fine to cut box lids off, but the lid must be secured to the box as if you hadn't already made the first two cuts on the box sides. First, put a shim on BOTH sides in the saw kerfs from your earlier cuts. Then CLAMP the lid in place on the box on both sides.
This way, it's as if you're making your first two cuts again, except on the ends, not the sides. Once you finish both end cuts, your box will still be solidly together until you unclamp the severed lid.
The second way to do this is to make your first two cuts all the way through. Then lower your blade so it doesn't cut all the way through the box ends -- almost, but not quite. When you finish the cuts, it's still a solid box. Now, take a utility knife and cut the top off through the thin sliver you left.
A.J.
