ADVERTISE HERE - FREE TRIAL
Anybody got the Kreg Bandsaw fence?
>Thinking of adding a fence to my Delta 14" bandsaw. Anybody got good or bad things to say about it? One of the reviews I read said it was flimsy because the far end does not anchor. I don't do a lot of heavy duty stuff on the bandsaw so I'm not sure it would matter a lot. Is there a better fence you would recommend?
Re: Anybody got the Kreg Bandsaw fence?
Mine is the old Fast Track--purchased by Kregg
>Good Afternoon Barry,
I thinkj I'm right that Fast Track was acquired by Kregg, and became the basis of the current Kregg jig. Maybe somebody will correct my assumption if I'm wrong. Anyway, its a nice jig/rig.
Its basically extruded aluminum with tracks cast into the assemble, permitting very easy set up, micro adjustment, resaw fence options (I have two sizes). I can remove the fence or re-install it in several seconds. I THINK THAT IS THE FINEST FEATURE. The fence is absolutely square, and is rigid despite being anchored only at one end-- my table saw fence has the same attributes.
My current 14" Jet came with a Jet fence already, and it was a fine fence. However, I liked the Fast Track fence I bought for my old Jet 14" bandsaw, and swapped it out when I sold the old saw to my #3 son. You'll be happy with the Kregg.
George
Re: Mine is the old Fast Track--purchased by Kregg
Lee Schierer - McKean, PA
>I also have the old Fast Track Fence for my 14" delta I picked it up from a company in Canada called Tuff Tooth that may have been the inventor. It comes on and off easily as George said. You can also adjust the fence with spacer washers to correct the angle for drift if you want. The washers came with mine. The fence is made from aluminum extrusions so it is stiff, but will flex under hard pressure. I don't have the micro adjust feature. The resaw fence comes on and off easily and works well as long as you get the center line of the curved surface aligned with the teeth on your blade. I recommend the fence.
Lee
Steve in Denver
>Haven't seen this in person, might be worth looking in to.
http://www.carterproducts.com/product.asp?product_id=474&cat_id=75
Very Interesting, but........
>Apparently those levers on the top raise and lower magnets that clamp it to the table. (?????) Not much info on how it works. Sort of expected a few more pictures or a video. If it works as it appears there would be no adjustment other than to release the magnets, move it manually and reclamp it with the magnets. That seems to be tedious if you have to sneak up on a thickness for veneer or a width of cut and maintain the drift angle.
They suggest it can be used as a table extension. That's an interesting idea.
Charles Yawn
>Barry, I have the Kreg fence system on my Delta bandsaw now. Thought well enough of it to take it off the previous bandsaw and install it on the new Delta. Have not had any problems with the fence flexing; probably because I have not put significant stress on the far end and because it is shorter than a fence on a tablesaw. I recommend it.
Charles
Larry in NW Ohio
>I`ve had mine for about 8 months now, and I really like it. I have it on an old Sears 12". It helped the old saw become alot better saw. I would reccomend it. Larry in Ohio
Darin in Victoria
>I've had my Kreg for a few years and really like it. You can adjust for drift, which is really nice. I like it much better than the piece of wood and clamps that I used to use for a fence :D
Yup I've got one...
Richter
>It's very high quality and mounts very securely. You can turn it on its side if you need clearance. It has slots to mount other things in. Overall a very high quality product and for the money probably the best fence on the market IMHO. I have one on my Jet 12" band saw.
