OT - Attics, insulation, flying squirrels, etc.
>I have a continuing problem with southern flying squirrels. I have killed one (glue trap) and relocated a few others (7-8), the most recent one this morning. They are in the overhead between my 1st and 2nd floors.
When the house was built, they used trusses with a 2 x 8 as the bottom chord (it could be a 2 x 10, I didn't measure). Anyway, there are thick batts of insulation between the trusses from the edge of the 2nd floor outer wall to the edge of the 1st floor wall. There is no insulation between the floors. There are batts of insulation on the outer walls of the 2nd floor as well as in the attic.
I recently cut an access hole into my attic and framed it in. I installed 1/4" hardware cloth along the length of the house between the trusses in the area of the ridge vent - this is to prevent the flying squirrels from getting in through the ridge vent area. I don't really know how I'm going to put hardware cloth or block up the ridge vents of the dormers. The roof is metal and somewhat "slick".
So - anyone have any great ideas as to how to block off the ridge vents for the dormers? Also - the batts of insulation seem to be blocking the ventilation from the soffit vents to the ridge vent in the attic. Anyone have any great ideas as to how I can insure ventilation? The attic space is cramped (maybe 4' tall) and I have a lot of trusses to work around.
TIA.
Re: OT - Attics, insulation, flying squirrels, etc.
>Are you sure they are flying squirrels and not small flying monkeys? Check your foundation and see if there are two striped stocking legs sticking out with witch shoes on the feet. That might be the root of your problem!
Tom
Always glad to help.
No, they are smaller and cuter...
>Besides, I've done several perimeter checks to check for holes in the siding. I think I would have notice some legs. And North GA is definitely NOT Kansas. We've got some relief to our landscape.
Re: No, they are smaller and cuter...
Lee Brubaker
>No suggestions...just comments. Flying squirrels can be very pesky critters despite being "cute". I recall when living in the Okanagan in British Columbia those little guys would get into the apple trees and cause havoc. Take a bite out of an apple then drop it and move on to the next one.No time flat strip a tree of its' fruit.
Lee
Scott in Montana
>I'm sorry I can't help with a good solution for keeping them out, but I can tell you that they are one of the few critters that the ultrasonic pest preventative devices actually work on. So that makes it a list of flying squirrels and bats. Out of desperation I bought one at Home Depot last summer for $14. and plugged it in on our back porch; haven't had any trouble since.
Good luck!
Scott
Fred Davis
>What part of Kansas were you refering to Thomas, ever been here, where I live and for two hundreds east , it's got relief to hell wouldn't have it, not to mention the flint Hills.
Congradulations on getting the Confederate flag down from the Capitol, now if you can solve Atlanta's water problem , you will be a hero for sure. ;-))
FredD
Frank G
>I don't know what a flying monkey is but a lot of the big monthballs seems to work for many rodents. Sorry to hear about another of this countrys heritage (good or bad) being restricted. Soon the real truth about the wrongs we suffered and the wrongs we caused will be erased.
