lining boxes
lining boxes
lining boxes
jacomb
>would appreciate suggestions on good techniques to applying velvet lining in small boxes
Re: lining boxes
All theoretical on my part
>never having gotten fancy...but the two approaches I've seen described are:
1. flocking, which requires buying the material (I think some craft stores carry it, and several of the online WW stores) and then learning how to put a thin film of the right glue on the inside of the box and blow the flocking material (which is basically velvet hair - that is, loose material) on. Always seemed like a disaster in the waiting to me, especially for those with children old enough to get in the shop but not yet old enough for good sense (mine entered Stage 1 about five, and seemed to leave Stage 2 about 20) - I picture flocked cats.
2. Wrapping, depending on the box dimensions, thin cardboard or thin ply, with the cloth, then hot gluing the assembly in place.
You might check your local library for box-making books. There are dozens of books on the subject out there.
Re: lining boxes
In practice
Bill Earl
>I've had good luck with method #2.
I've used both thin wood and heavy card-stock to make liner panels for boxes. Wood is the better choice for larger boxes. Wrap the liner panels with the velvet and install them in the box.
I usually make and wrap a separate panel for the bottom and for each side. When cutting the parts for the liner, make sure to take into account the thickness of the velvet.
For wrapping the panels, I've had good results with both white glue and wheat-paste (wallpaper paste). Wheat paste is a little more forgiving if you mess something up.
For installing the liner panels, white glue or carpenters glue work well. Just make sure to keep it away from any visible edge. I'm not a big fan of hot-glue.
Re: lining boxes
Re: In practice
Doug Reynolds
>I buy the self-adhesive stuff from Rockler and usually end up mounting it directly to the drawer bottom. Good results if the fabric is positioned in exactly the right place before sticking it down because, when I have tried to reposition it, it stretched and no longer fit nicely. Plus, it is hard to trim once in place. I have tried the cardboard thing and keep it in place with double-sided carpet tape. Just a little piece so I can remove it and replace if needed, like if something spliils in the drawer. I also have watched the on-line video by DonJer and it looks simple enough though two applications may be necessary. Since the glue and the flocking are the same color, it may be very nice.
Re: lining boxes
Consider Ultrasuade instead
Re: lining boxes
Re: lining boxes
Charles Yawn
>I have had good results with the flocking method. Following the instructions works surprisingly well; and I do not have young children or cats, and the wife knows not to touch nothing while in the shop!
The only complaint is that sometimes I would prefer the layer of material to be thicker.
Charles
Re: lining boxes
Louie Lovas
Re: lining boxes *LINK*
Louie Lovas
>I have made a few jewelry boxes and used self-adhesive Velvet which I purchased from Rockler.
It's best not to have any exposed edges of the velvet that could possibly peel back in time. I've managed to achieve that in my designs.
I like this stuff because if you get any dust on it you can simply brush and vacuum it.
Rockler Self-Advesive Velvet
Re: lining boxes
Re: lining boxes
DizD
>I've been using a felt board product I get from a trophy business. It is a felt surface on a heavy paper like mat board. Cut to size with a razor knife & drop it in the bottom. Can use a little double sided tape to hold it down, if needed. I've not tried to line sides of box with this.
Re: lining boxes
Re: All theoretical on my part
Jim Pugh, Elyria, OH
>Flocking is simple to do and Rockler now has it available plus a Flocking Gun, ~ $6 to put it in place. Just follow the directions. Seal the piece with shellac, use the adhesive the same color as the flocking, put/blow the flocking on at the proper time and let it cure overnight. Brush out the excess - which can be saved and used later.
Re: lining boxes
Re: lining boxes
Robin Corell in Atascadero CA
>I use PSA felt and I cut it to size before peeling the backing off. There is a bit of a lerning curve for getting good results so be sure to get enough extra to do a few parts over.
Re: lining boxes
How about leather?
>My wife finds old leather coats and we recycle the leather for crafts, etc. Additionally, stores like Hobby Lobby and Michaels sells new leather for things like that.
Happy Woodworking!
Re: lining boxes
Sprayed suede ?? work's
del schisler
>have you thought of sprayed suedetex ?? Lots of colors I have made 100 or so jewelry box's and have used sprayed suedetex I got the spry gun Cost a little more But it is worth it If you get it Use 15lbs of air pressure This seems to work good this work's very well and is easy to use And looks very nice lot's of different color's here is the link
http://donjer.com/suedetex/product.htm
Re: lining boxes
Additional experience with this approach
Bill Tindall, E.TN
>The jewelry box I entered in the contest has the drawers lined by this technique. Poster/mat board was used for the substrate and velvet cloth for the wrap. We used white "craft" fast tack glue or rubber cement, I can't remember which and just glued the fabric on the back of the poster board. My daughter did the wrap and she had a trick for the corners that eliminated the bulge where all the folds came together. There was some piece of fabric that she cut away at the corners so that when they were folded onto the back a bulge from several overlapping layers was eliminated. Email me off line and I will ask her details if you can't figure it out.
Re: lining boxes
Re: lining boxes..vinyl floor tile
pecker
>If you're choice of fabric isn't peel-n-stick, you can use adhesive backed floor tiles. Cut the tile to be 1/16" smaller than you're drawer bottom. Remove the peel off sheet from the back. Wrap the fabric so that the waste side is embedded in the adhesive. You may have to trim the fabric so it doesn't bunch up.
Re: lining boxes
Re: How about leather?
Art Liebeskind
>Leather will tarnish the silver things in the box
Art
Re: lining boxes
Oh... thanks
>Oh, I didn't realize that. Thanks.
Guess I'm not much of a jewelery type guy.
Happy Woodworking!
Re: lining boxes
Crushed velvet
Grant in Iowa
>I have used crushed velvet in blue, black, or tan. Available at fabric stores in several colors, this provides a nice plush thick and durable covering.
TO apply, I have cut the piece to fit (maybe a touch large), then spray the back of it with 3m spray adhesive (costs more than a linear foot of the crushed velvet), and apply to drawer. You can spray both surfaces for a contact cement like grab, but I usually only do one side(the fabric).
I have used this on bandsaw boxes, which have curved bottoms...works great, looks great!
If you will be doing the inside sides of the boxes, then maybe make the piece a bit oversize so you can be sure it will cover completely. Trim along the top edge of the drawer with a sharp blade after it is glued in place.
Regards,
Grant in Iowa
