Steam Bending Articles?
>Hi,
Can anyone point me to any articles (how to) about steam bending wood? I need to know how to build a steam bending setup etc.
Thanks in advance!
Tom
>Hi,
Thanks in advance!
Tom
Re: Steam Bending Articles?
>The easiest way is to take a 5/8" (or 3/4") sheet of ACX plywood and rip it into ~9" wide strips (or less). You'll want them longer than the longest piece you are bending. Mine is ~80" long.
You can either suspend your box on top of a turkey fryer "pot" or port a radiator hose into the box. If you use the turkey fryer method, you have an opening that is the width of the pot on the bottom of the box. You'll have to cut covers to put on either side of the box to "seal" the top of the pot.
Anyway, make a rectangular box (with or without an opening). You'll want either hardwood dowels or stainless steel bolts going from one side to the other. You'll want enough dowels or bolts to suspend your pieces above the bottom. A spacing of 8-12" is good. You may want closer spacing at the ends.
Drill "drain" holes near the ends on the bottom (1/4" or so). Drill a "relief" hole in the top near an end. About 1/4 of the way to an end, drill a hole for your thermometer.
Plugging the ends - you can either use some of the ACX plywood and make fancy ends or use foam. I used the foam.
I have mine on a stand. I use an old pressure cooker to supply steam through a radiator hose to a stainless steel nipple mounted on the bottom of the box.
Here's a url to a box similar to mine.
http://www.ceolas.org/instruments/bodhran/santin/MakeBox.htm
prit-near everything you need to know *LINK*
Bruce, a MN Galoot
>about steam bending can be found
here
Jim Shaver - Oakville, Ont
>A couple of good books out there, check LV.
Michael Fortune is also the master at this, google his name and see what you can find
Take care,
Jim
Do I smell a chair on your drawing board?
Robin Corell in Atascadero CA
>I don't have pics of the box I made. sometime in March I will be visiting the friend I gave it to when I moved and I can get some pics if he still has it.
I used a 8" diameter piece of schedule 40 PVC that someone gave me. It came with a cap on one end and I made a wood cap for the other end. I made a litle grid like frame out of some 3/4"x3/4" scraps that fit in the pipe and made a flat area off the bottom of the pipe for the wood to sit, there was space between the frame and the pipe for water to drain. I made up a base out of some 1x2 to hold the pipe at a slight angle and the base had a shelf for a double burner hot plate and a couple of tea kettles with some tubing that conected to a fitting installed in the PVC end cap. I also drilled a 1/16" hole on the bottom side of the end cap for the water to drain into a pan. I should have plumbed it with a drain tube as it used to make a puddle no mater where I placed the drain pan.
with a single tea kettle it took over an hour to get up to temp. when I added the second tea kettle it dropped by more than half. once it is hot it recovers pretty quick when taking a board out. I used to charge it with a full load rather than putting a piece in when I removed one.
It is pretty straight forward and no matter how much you read you will still have to do a bit of trial and error to find out how much spring back you will get for each part and for each type of wood as well as how long it tkes fro your parts to become pliable.
Robin
Ps. Wear gloves
Re: Do I smell a chair on your drawing board?
>Chair? Maybe. But first some experimenting in the area of pure art form with little function. Thanks for the info!
Tom
Re: prit-near everything you need to know
>Thanks Galoot!
