wood identification?
Pat Evans
>This plank is glued up from 3 slices of a 3"x3" board a friend was about to throw in the campfire. I darkened a section with mineral spirits to show the grain better. The wood is surprisingly heavy but easy to work. However, it smells awful when cutting or planing. Any idea about what it is? Thanks.
Re: wood identification?
End view
Pat Evans
Looks like ipe
Ray Binnicker
>I will vote for "Angelim" (Angel Heart). I'm seeing a lot of it show up as cut-off's from the flooring industry. If it is Angelim it is pretty grainy, but turns pretty well, and finishes pretty well. For sure too many uses than firewood.
Ray Binnicker
I Vote For Elm
>Looks like Elm to me. Has the ray flecks that Elm has and sounds like it stinks like Elm.
Tom
I agree.
Lee Schierer - McKean, PA
>If it is Ipe it will not float.
Lee
It floats
Pat Evans
>I dropped a 1/2"x2"x6" piece in a bucket of water and it floats. Must not be ipe.
Re: I Vote For Elm
Pat Evans
>Although it doesn't show well in the picture, there are a few areas that appear splotchy. Up close, the splotchy areas are very smooth with no porous appearance. You still see the grain, but it looks like someone had used a sealer on them. Is that typical of elm?
Re: End view
Larry in NW Ohio
>I hardly think of myself as a beginner let alone a novice to contradict Thomas Skaggs, but I was told I have Elm and it doesn`t look like that, unless what you have is QS.A guy from Frank Miller Lumber was at my place one day and I had some wood here I was told it was Oak, but it didn`t look like it or weigh like it. I seemed like it was twice as heavy. Well he looked at it and didn`t even blink an eye and said it was elm and I don`t think it looks like what you have there. I could easy be wrong, that it may be cut different or something. But mine does not have any black streaks in. Larry in Ohio
Then it must be
Henry Higginbotham
>. . . witch-hazel! (Sorry, couldn't resist. Monty Python made me do it.)
Re: What else floats in water?
Brian in Brighton
>Very small rocks......
Cider......
A DUCK!!
Therefore if she weighs the same as a duck, she's made of...wood.
Ha Ha Ha
Build a bridge out of 'er
