entertainment center
brandon mclean
>Should I use 1/4 inch or 3/4 inche plywood for the back of an entertainment center?
brandon mclean
Re: entertainment center
Mamc
>I always use 1/4 inch for the back unless there would be a structural reason to be thicker. I cant think of one! Also keeps the piece light.
Larry in NW Ohio
>I would think 1/4" would work the best, 3/4" work be overkill and add a lot of weight. Best of luck with your EC. Larry in Ohio
Stephen Kirk in Quakertown PA
>I gotta think 1/4" would be fine. However, wherever you are housing all the electronic componenets, make sure you have good ventilation through the back, plus some good sized holes for cables and such. This is really important if the components are behind doors. The electronic components can create a lot of heat.
kalebhjones
>Id go with the 1/4, the 3/4 would be too heavy when trying to relocate it.
brandon mclean
>Thats what most are tending to tell me as well.. Thanks for the response..
brandon mclean
>Thanks Ill need it!!
brandon mclean
>Okay..
Thanks for the advice everyone..
Kaleb Jones
>Okay.. thanks for the advice about the ventilation.. I will do this for sure..
