THE WOODRAT IS BACK!
TS Switch Saga continues
Rick in Jackson
>Thanks for the previous advice, got a nice paddle switch from Grizzly. Now on to the "electrical challanged" question. On the back of the switch it has two terminals on each side, one marked LOAD and the other marked LINE. Does it matter which side the black and white wires go on? I'm thinking white goes on the LOAD side and black to the LINE but wanted to be sure, again, appreciate the help. Rick
Re: TS Switch Saga continues
John Luke
>Rich, drop that switch and back away from it for a minute.
The way you're going to wire it will result in a direct short when switch is turned ON. Actually, I would like to be there to watch, would be an impressive explosion when switch blows up in your hand.
OK, now you have two terminals the line side and two terminals on the load side of the switch. The load side will go to the motor (load) and the line side goes to the incoming line cord.
One black, one white from the line goes to the line side of the switch, and one black and one white goes from the other side of the switch to the motor (load). Make sure that wire colors carry through the switch, meaning that when the switch is turned on the black line is connected to the black motor lead and the white line is connected to the white motor lead.
Hope that I explained this clearly to you.
Howard Norman
>The LINE markings are for the incoming AC. The LOAD markings are for the motor on the saw.
Chuck in ND
>If it has 4 terminals I'm thinking it is a 120/240 V switch. 2 terminals for 120 V, 4 terminals for 240 V. If you don't know what your doing, call someone that does, and let them do it.
Rick in Jackson
>John, Howard, thanks for the help. Glad you warned me and sorry you couldn't be here to watch me blow myself up :) I have attached a rough drawing of what I took away from your explainations. Again, thanks for the help. Rick
Rick in Jackson
>Thanks for the advise Chuck but a man has to learn somehow and that's what is so great about posting and responding to question here at Wood Central. You can always get good advise and learn so much.
Larry in NW Ohio
>Rick You need to make sure that your plugged in to 220v, if that is what you have then you wire your switch the way previous posts tell you. Just make sure you are hooked to 220V. Larry in Ohio
Chuck in ND
>He never said if he's running 120 V or 240 V. But usually on a switch I only hookup the hot leads, and then wire nut the neutrals.
Rick in Jackson
>This is 110 not 220 so now I am (more) confused The switch is rated for both 120 1 phase 2 HP or 240 1 phase 3 HP
Alexander Grigoriev
>Never mind. There is nothing wrong with disconnecting both hot and zero wires for 110V, even though you only have to disconnect the hot one. If you were running 240V, you must disconnect both, though, because both wires are hot.
GalenV
>I hope your power cord also has a green ground so you can secure it to the metal of your saw. That said it will only help if you know it is being plugged into an outlet that is grounded!
Chuck in ND
>You can hook it up the way you have it drawn out.
Explosions
>"...sorry you couldn't be here to watch me blow myself up...."
I just love to watch stuff blow up..... stuff, not people.
On behalf of everyone here, I can tell you that the interest would have been to see the switch blow up, and certainly not you.
Happy Woodworking!
Re: TS Switch - Problem Solved
Rick in Jackson
>That's what I did Chuck, thanks again to everyone for their help and comments.
Re: Explosions
Rick in Jackson
>And Mark, I did it all without blowing anything up :) Sorry to disappont you guys...maybe next time..Have a great weekend
John in Calgary
>Interestingly, I've done this and luckily there wasn't an explosion. We actually melted where the main panel breakers attach to the load bars that form the backbone of the breaker panel.
I agree though that you should back away and make sure you don't connect the white to the black across the switch!
John
