Router raizer at Columbus show
Larry in NW Ohio
>I`m goin to be looking for a router lifter at the show this weekend. I`d like to have one with a very good measurement reading. What do you think is the better one. I know this is going to go all over the place. That`s OK, everyone has their own opinion. I`ll read everthing and deside what`s better for me. Thanks to everone who thkes time to write. Larry in Ohio
Re: Router raizer at Columbus show
Dave Paine
>You mention "very good measurement reading". I am not sure what you have in mind.
I have a Unilift from www.woodpeck.com and have been happy with its ability to make accurate adjustments from a given point, but it and others like it, do not measure.
Jointech (www.jointech.com) are advertising a lift with digital readout.
I recently upgraded to a PRL-V2 from Woodpeckers. I thought this would be faster to set. So far mixed feelings. It is faster to make quick adjustments, but the fine adjustment only covers max of 3/4in from wherever the course adjustment stopped. This unit does allow setting the measurement wheel to zero before making the fine adjustments.
Both the Unilift and PRL-V2 have sufficient fine adjustments for my use, but they may not be what you want as "measurement".
I have not used the PRL-V2 much, but with the Unilift I was able to reset a bit to the same setting to re-do an operation after making height adjustments. It just took many turns of the fine threaded rod.
I am not sure I would believe any readout. I would want to make a test cut, measure with calipers, and then trust the "delta" measurement of my lift.
