Sanding discs =�PSA and . . .
Nathan
>Very soon I'm getting a bench sander with a fairly large (14.5") diameter spinning disc. So soon, in fact, that I've started to get serious about getting some sandpaper for it.
Now, there are two varieties of round sandpaper of the required diameter I could buy. First is PSA (Pressure Sensitive Adhesive) backed and the second is just the paper with no adhesive. Needless to say, the latter is cheaper than the PSA - in fact, half price.
So, I would like to go with the plain non-PSA sandpaper but that brings another question - how to put the sandpaper on the disc so it doesn't fall off, but at the same time it should be fairly easy to peel off when the sandpaper wears out and needs replaced. I vaguely recall there being some kind of spray-on glue for this purpose.
Does anyone know what the "best practice" is for larger-diameter bench sander discs? Go with PSA at a higher price or . . . ?
