Quite A Lot Of Milling To Form
>Hello Mike,
Some of the saws require more milling than others. My new Jet Hybrid is a real pain to make ZCI's for, so I am fairly limited in choices of materials. I chose solid wood, and currently am using white oak and a couple on maple. I can thickness these to gross thickness and further machine with forstner bits, those areas which sit upon insert rests cast into the iron table. The steel insert which came with the saw is very thin, but has integral stiffeners. I do not dislike the saw's lousey insert design enough to become unduly emotional, but its a bad job on a good saw. Solid wood is the only way I can go, other than rewarding somebody for Jet's bad design by buying an after market ZCI.
George
