Highland Hardware Woodslicer first impression
Dave Paine
>I just received my 3/4in Woodslicer bandsaw blade from Highland Hardware and so I felt compelled to install and do a test drive.
First impressions are "wow". I tried 3.5in high mahogany not a good test) then 6 inch pine and finally 8 in high black walnut. Even the 8 in black walnut cut with the same ease as the 3.5in mahogany. The slice was about 3/32in (not aiming for a specific thickness, just thin) and was very consistent - just like the site promised.
I had recently been frustrated at my attempts to resaw similar woods with another companies 3/4in resaw blade which is almost new. This other blade does well in other cuts, but for re-sawing has a lot of drift which resulted in a major thickness variation and a lot of waste. The cut pieces had to be planed to achieve consistency, and in some cases "lost" 1/4in thickness.
What a differnce. The Woodslicer cuts with less pressure and does not drift. The other blade's drift was causing me some big problems.
I still like my other blades for normal sawing, but I am impressed with the Woodslicer's first tests.
Tomorrow I will try maple. I just need to dig through my scrap pile to find a "volunteer".
I was also pleasantly surprised at the packaging. The entire blade is wrapped in paper, and then put into an envelope, which in turn is put into a box. Very easy to handle.
I may be late to discover this blade, but so far it seems a very good purchase.
