Cutting Aluminum
Cutting Aluminum
Cutting Aluminum
Rod Rentz
>I was told that you can cut aluminum stock on a chop saw with a carbide blade. Is that safe?
Re: Cutting Aluminum
Mark Nowicki
>Yes, with a negative hook blade. Mine is made by Vermont American.
Usually they are marked "non-ferrous metal" and/or "laminate"
Mark
Jay St. Peter - SoMD
>It's safe if you make it safe. Don't try to use your dust collector since molten aluminum will go light it on fire. It is useful to be able to clamp the Al in place as you cut as it will catch much easier than wood. Also (related to my first comment) the chips flying off will be hot, keep your skin out of the way ;).
Jay
>I have cut aluminum and some copper with my chop saw, band saw and table saw. With carbide tipped blades. I would not recommend it though. It was nasty in terms of chips and filings. They went every where and stuck to everything. Took a while to get them out of the bandsaw tires and my skin. Be sure to wear excellent Eye protection. You don't want these bits and pieces in your eyes.
william h. falberg
>Be sure it is solidly clamped; go slow; and keep spraying the blade with water. I use a Windex spray bottle and shoot as fast as possible for the center of the blade. It tends to centrifugal outwards and flow into the teeth, where it's needed. If you hook your shop vac to the exhaust vent it will minimize overspray of dust/chips. It comes out pretty fine, but shouldn't be hot. If you cut aluminum dry in a 10" chop saw with an eighty tooth blade you'll gum up the blade real fast . THEN you've got a problem, because it'll send molten pain everywhere. So, the magic words for today are tight and wet. You can do it with a skil saw too, but it's harder to get water into the blade, so watch out there.
Cutting Aluminum.. funny you should ask
Gary Camp, Bend, Oregon
>I just got done cutting some 3/16" Al on my tablesaw at work. I routinely make jigs and fixtures using Al. I cut it on the tablesaw and and various "chop" saws using WoodWorker II blades either 40 or 60 tooth. At one point in time Bridge City Tools claimed to cut all the non-ferrous meatl for thier tools with WoodWorker II's. All of the above cautions apply for PPE.
glc
Larry in NW Ohio
>Of course I go against the wave here, I cut Al with my bandsaw W/ pretty much whichever blade happens to be on it at the time, and so far I have not had any trouble yet. But I do like to use a 4tpi blade, and they are not carbide, although it would be better. I don1t like using my TS or chop saw becausr of the FLYING chips. This is the way I`ve always done it, but I don`t think I`d cut anything thicker than3/4". Be careful however you do it. Larry In Ohio
Fred Davis
>Every Glaziers shop I have been in used a steel blade 10" blade made specially to cut Aluminum, they must have at least a hundred teeth on them ,mounted on a chop saw.
Sawdust size filings were produced , rather then the large chips made by a carbide wood cutting blade.
If you use a bandsaw or Sawzall , run a Paraffin block or candle over the teeth, this will prevent clogging and bonding of the Aluminum to the blade.
FredD
ThomD
>You can use just about any blade on a circular saw to cut aluminum, but the less teeth on the blade, the slower the feed. Lubrication always helps, though is not necessary with al. Something like beeswax would help.
Safe it may not be without the right blade. Proper rate of feed, and lots of skin and eye protection are a must.
call me paranoid
Steve Jenkins, McKinney, TX.
>When I cut aluminum on my tablesaw I not only don't turn on the dust collector but I disconnect the hose and move it out of the way so chips can't fly into it. Besides the concern of fire I don't want aluminum chips in my mulch.
steve
Re: call me paranoid
Rob Stokes in North Vancouver
>Aluminum is non-ferrous and will not produce sparks. It's also a fantastic conductor of heat meaning the hot chips created when cutting will cool almost instantly as they fly away from the blade.
There's nothing wrong with being cautious, but cutting aluminum with woodworking tools (if done properly and carefully) is safe.
Rob
Rick L
Re: Molten aluminum, silly fear...
Rick L
>Got to be kidding. It doesn't get anywhere that hot. I cut lots of non-ferrous metal as a Metalsmith on my table saw, including brass, zinc, aluminum and copper. It's warm, not molten by any means. A negative hook carbide blade is the recommended blade, pretty much the same recommended blade for radial arm saws and most chop saws. Recommend a face shield, other than that it's not much different than cutting wood.
You can tell the ones who never did it...way over blown words of warning and fears of molten metal!!!!!!!!!!!!!!!!
True, but the chips can get very hot...
John in NM
>I used to have to cut aluminum with a router at one shop I worked for. Man those little chips got hot! Definitely not molten or even close, but might be hot enough to start smoldering in a pile of sawdust. Though the specifics might be wrong, the caution is not.
