dangerous router practice
Fred Davis
>Here is a observation I have often wondered about, particularly when I repeatedly see it described in wood magazines and even recommended as a way to reduce tearout while doing a router run with a hand held router.
That is the practice of climb cutting when you run into a interlocked or reversed grain,
Having done this for many years , I know how dangerous it could be for a first attempt, when a novice really doesn't realize how much power the router can exert trying to leap out of your grasp , often ruining the wood profile cut and maybe taking a chunk out of your front end.
Depending on the size of the router bit and the depth of cut , it is a practice that requires all of your attention and focus and can still occasionally backfire on you.
One note about chainsaw use, in California, OSHA came out in the late seventies with a preliminary caution about a rule being considered , that would require guards on chainsaws while in use.
Naturally this didn't happen for obvious mechanical reasons and the rule never became a requirement, but it did show the rididculous lengths that desk bound governmental dimwits would go to ,in order to make themselves feel needed and important.
So I would say from my point of view , if you climb cut , be very careful.
FredD
