Table saw surround
Table saw surround
Table saw surround
Reid
>To all,
I'm currently moving into my new shop. I've got an old Delta Unisaw and am in the process of building an outfeed and side table for the saw. I've framed up the table substructure using 2x4's and 2x6's. Next step is to add the tabletop. Should I use 3/4 inch plywood or would MDF be a better material? If I extend the miter slots out into the outfeed portion of the table - would one material hold up better than another? I'm also thinking I will put a piece of 1/4 inch masonite on the top - so I can replace it when I need too. Will I need to somehow fasten the table surround to the actual saw? I've got the framing within 4-5 inches of the saw on the back and to the right of the saw - so I'm thinking I should not have problems with the table sagging adjacent to the saw.
In addition, I decided to raise the saw a little by putting two pieces of 3/4 inch underlayment under the saw. However, it seems like the saw wants to move around on these boards if bumped slightly. Maybe this will not happen when the entire assembly gets completed - or should I plan on trying to fasten it to the floor as well?
Any help on any of these questions is very much appreciated.
Reid
Re: Table saw surround
Re: Table saw surround *LINK*
mdclor
>Reid,
You can see a picture of my surround at the link below. I did attach my surround to the TS to ensure that it didn't walk around. I subsequently put a sheet of melamine on top of the plywood so I could also use it as an assembly table without having to be concerned about the occasional glue drip. I also tried to get the surface as flat as possible again to accommodate gluing up pieces. Therefore I used jointed 2x4 supports on 16" centers under 3/4" ply and then the melamine. It isn't perfect, but is within 1/16" across the surface I think.
HTH,
Merle
my shop
Chuck in ND
>I've always used MDF and then laminate it with Formica. If your concerned about wear in the miter slots, brush a couple coats of Poly or whatever you want to seal them up, or Formica then too.
>FWW's current Tools and Shop Issue had the "Best Ever Outfeed Table" as the cover project. I have not read it thoroughly because I am not in the market, but they may have it at the borgs or wherever fine magazines are sold or maybe even on line.
I have rollers for an out feed, so take this with a grain of salt. In stead of cutting slots for the miter gauge, I might make the top a half inch low and make it out of sturdy but common stock. Then add a layer of half inch melamine in three pieces leaving gaps for the slots. I'd make the slots a little oversized to avoid alignment problems. I'd let them go all the way across so you can sweep the trash out easily.
Chet Kloss
Awesome Shop Merle
Chet Kloss
Dean Johnson
>I've lurked here for quite awhile, but I'll try to share and idea I used for a "surround" for my table saw (general contractors saw). I'll try to post a link to an album of my shop photos that include pictures of the "island" near the bottom.
Essentially, I constructed two cabinet structures, co-joined them with "Uni-strut" -- covered then with a sandwich of MDF and Melamine panels (heavy duty kind used for racquet ball courts) --created an opening to slide the table saw in. It's still in progress, but so far has worked well as both an outfeed and assembly table.
view the shop photo album
Jesse Cloud
>Wow! That is one sweet shop!!
Robin Corell in Atascadero CA
>Years ago I made some out feed tables for a commercial shop I worked at. for the out feed table the leading edge had a 2x2 added to the apron so it would fit over the top of the angle iron that is on the back side of a biesmyier equipped PM66. There was a pair of bolts sticking out from the bottom of this that fit in a pair of holes drilled in the angle iron. The table was lifted up an inch and then dropped into these slightly oversize holes and this kept the table registered to the saw so the miter slot extension grooves would always be aligned. Finding out at the end of a cut that the table has moved 1/8" and the slots don't match can be dangerous. You will also want to drill a 3/4" hole at the end of the miter slot so accumulated saw dust can fall through.
Our tables were lacquered particle board with a coat of wax. They got a couple of fresh coats of lacquer every year and held up for cutting dozens of units of ply and particle board each year. For our application particle board was best as it allowed us to screw fixtures to the tables when necessary and it they got too massed up you could unscrew the top and flip it over or just replace it at a minimal cost.
Robin
Shop Contest
Alan in Little Washington (NC)
>How did you do in the Shop Contest?
Jim Dillon
>Reid,
I used 3/4 inch plywood for my outfeed table, and 3/4 inch MDF for my extension table. My extension table actually fastened between the TS fence extensions which made it easier to do. The outfeed table was bolted to the back of the TS and made roughly 1/32 inch lower than the TS top. I cut slots for the miter gauge/sled etc. in the 3/4 inch plywood and reinforced under the slots with another layer of 3/4 inch plywood. I gave the MDF multiple coats of Watco clear danish oil (top and bottom), let dry, then coated with wax. Seems to work OK and has for 10 years.
Personally, I would try to have the extension table and outfeed table fastened in some way to the TS. I guess I just feel more comfortable with the entire thing being one unit rather than separate units.
Regarding TS movement. How about this idea. Make four pads (2 x 3/4 inch plywood), say 12x 12 inches. Then add a third 3/4 inch layer with a hole cut in the center for the TS roller to go into. Place a pad under each wheel and maybe the TS will resist movement. I have seen nice homemade mobile bases in various mags, but I can't recall where right now 8-(. Hope this helps.
Jim
Re: Awesome Shop Merle
mdclor
>Thank you. This is my third shop so when we built the house I thought that I knew what I wanted. Turns out I was wrong again and would do it differently if given the opportunity, but that is a very remote possibility. I think SWMBO would stroke out if I suggested it. :)
Merle
Re: Shop Contest
mdclor
>Didn't enter due to perceived shortcomings in design and placement of major tools. Too many opportunities for improvement.
Merle
Reid
>To all,
I wanted to thank everyone whom responded to my questions. Now I have plenty to think about and am much more confident I will not be making a stupid mistake. Thanks again to everyone.
Reid
