Info on dust collection needed.
Stuart Hough
>I have a small gara....er...shop that I use, and need to get some dust collection going. Don't have a lot of discretionary funds, so I'm looking at the new Delta DC that replace the AP-400. It moves 650 cfm, has a 1 micron bag on top and a clear plastic bag on bottom. My query is this...will the addition of a cyclone lid on a 30 gallon trash can pull the airflow down too far to be effective on my TS and planer? I would love to get the Oneida Gorilla series, but even their smallest is out of my range right now. Any advice is greatly appreciated.
Re: Info on dust collection needed.
>I have the larger Delta unit that in supposed to move about 1200CFM (IIRC) and I have it ducted through 6" and 4" S&D plastic pipe. I have a home made separator I made out of a roll about Rubbermaid Trash can. I put sticks up each corner to keep it from collapsing. I used a couple of 4" duct fitting on top of the can and it worked fine. Used it on my TS and lunch box planer mostly. Did a good job and did not seem to rob too much suction. It helped to reduce the number of times I had to empty the bag which was a PITA. Turned out the trash can was always in my way. (Small shop blues, one car garage) So, I rearrange the DC unit to make it easier to empty the bag. One thing I did was buy a 30 gal. metal trash can and put the bag in that as liner. MUCH easier to handle. The can is about four inches shorter than the bag and that leaves a clear space so I can observe when to change the bag.
Chuck in ND
>I think if you make sure that you have a good seal on the trash can lid you'll probably be ok on one tool at a time.
David
>I've got an older, maybe 10 years now, Grizzly 1 1/2hp DC that pulls through a cyclone lid on a 30 gal metal garbage can. My runs tend to be long, around 10 ft from tablesaw or other machine, to the DC. This set up does ok with my lunchbox planer and smaller jointer (6"). It was OK when I was using a glorified contractor saw (the one Delta replaced with the hybrids). Can't seem to keep up with a cabinet saw. Dust collection under the blade is fine, over the blade is all over me. Large jointer (16") fills the garbage can too quickly. Hope this helps.
Thanx for your replies!
Stuart Hough
I know emptying the bag can be a PITA.............
Art Silva
>but if you wait until you can see sawdust in the top 4" out of the can you have seriously degraded the performance of the dust collector. Ideally, the bag should be dumped when 1/2 full.
