For Lovers of Old Arn -- & Gary Evans
Mike Fitterling
>I had a very old Dewalt GP that I was going to restore for service in my shop. I love the old Dewalts and use my RAS probably as much as my tablesaw. Anyway, the ways were bad and I found out, after sending it to Original Saw, that they were too far gone to remill. Bummer! Lots of work and no RAS in the shop because I had sold my modern Delta when I got the GP. Rayts!--What to do? What to do? Then in "Classifieds" I saw an ad for a Dewalt that Gary was selling. Took a lot of doing and generous help from several fellow woodworkers to get the saw from TN to FL, but we pulled it off.
I left the legs off and set it on a plywood "cabinet" I built. It came with a auto-return bracket, which I left off (I don't like the idea of anything moving, unless I am the one moving it.)
The cabinet has a leveling leg in each corner as do the cabinets under the counters on each side (they have six legs each), so I could level everything to everything else, making the RAS table level with both extensions. The cabinet does not span the whole width between the counters because the handle for controlling the blast gate passes through that space and gives me access to the ducting. Once everything was dialed in, I attached a 2x4 support on the left cabinet end to support the saw base hanging over that gap.
On top is a new Mr. Sawdust table. I epoxied steel bars not only across the table but also from back to font to support the large overhang. The table is 48" wide by 26" deep at the center. The saw can crosscut more than 24" so I wanted to have something out under the end of that spinning blade when all the way out.
I went through all the steps in the Mr. Sawdust book to align it and was surprised at how little it needed tweaking, especially after that wild ride in the back of a trailer all the way from TN.
This is a 14" 3hp, 3 phase saw, run by my RPC. It has so much power that cutting through some scrap boards I could not tell a difference between when the blade was spinning freely and when it was in the wood. Reminds me of the feeling I had moving up from an old Craftsman contractor saw to a 3hp cabinet saw.
Brian (Holbren) helped me out with a new blade for the saw. When it got here I saw it had no beveled teeth at all and instead it was triple chip, flat raker, triple chip, flat raker; made for cutting aluminum at that. I thought for sure it would cause all sort of tear out, but the first cuts were as smooth as glass, with no exit tearout. I cut with and across the top veneer grain on plywood and, then some cypress, and some cherry--all with excellent results. I want to use it for a while and see how it does in other stuff, but for now I am a believer. It is a 14" Tenryu 100 tooth -3 rake "Alumi-Cut" blade. Haven't tried out the new dado stack yet.
Thanks, Gary! I couldn't be happier. (And, by the way, I got the original switch working.)
Cheers,
Mike
Re: For Lovers of Old Arn -- & Gary Evans
Larry in NW Ohio
>Mike That is a great RAS or GP, I`m at a loss what that means. We had two of those where I use to work, in my former lifeand you are right, you can cut a 4" X 4" and can`t tell when you are cutting the wood. Don`t make them like that anymore, and I assume the reason for that is, they would never sell another one to the same buyer, because it would out live them a couple times over. Larry in Ohio
Mike Fitterling
>Thanks! Original Saw still makes their version of a GA, but at a much higher price than what I paid for this one. ;)
GP is another model DeWalt radial arm saw; with a 12" blade. The GA, which I have is a 14".
Gary Evans Tallassee, TN
>Very nice job, Mike!
It looks like it is quite happy in its new home. I'm glad it worked out good for you.
Gary
Nice looking saw. I'd be frightened :).
>That's a mighty big blade.
Scott Greaves in Blackfoot Idaho
>Mike,
That is great! I'd like to find a fan of old arn near me. I'd donate an old DeWalt RAS to somebody who would try to restore it. I bought one thinking I might like to restore it myself, and found that I'm really not inclined towards that. But I really respect people who do bring old machinery back to life!
Scott.
Mike Fitterling
>Post it here, at owwm, or over at Woodnet. It would be a shame for one of those great old machines to go for scrap when someone could be using it. Although, that is what I am going to have to do with what is left of my GP. At least some fellow woodworkers got use out of some of the parts.
