Unisaw magnetic switch wiring question
Mitch from Canada
>Hey again all,
Ok, I was all set to wire up my two hot wires to my 8 year old unisaw on L1 and L2 of the switch (this is how my father in law/electrician said most units are wired). He didn't have the switch cover in front of him and didn't see the wiring diagram inside which states "For single phase motors..Line connections are made at L1 and L3." I called him on the phone about it...he said normally it's L1 and L2 but if that's what the diagram says, then to try it.
Can anyone here tell me for certain that L1 and L3 for the two hots coming in from my extension card are correct?
I just want to NUKE the magnetic switch.
Thanks again,
Mitch
Re: Unisaw magnetic switch wiring question
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>I think mine may be a little older than that one, but the lines in, are L1 & L2. There is not even a L3 in the box.
However I have seen plenty of other switches where L1 & L3 are the ones used. If that is what is shown on the inside diagram, that is what I would try.
More importantly is to make sure that you have the wires in the motor match the voltage brought into the switch.
The switch for that saw may be able to run on three phase. If that were the case, then all three of the L wires would have a hot lead to them. But for single phase, the protection is usually run through L1 & L3.
I don't think you can fry anything by using those, as long as you have the wires in the motor set for 220, if that is what you are hooking up to. If you are not sure, I would sure pull the cover off of the motor wiring to make sure.
Mitch from Canada
>Thanks Keith,
I just wanted to be sure.
Mitch
Larry in NW Ohio
>Mitch I just went and looked at my unisawand the connections are at L1 and L2 the same at the top as it is at the bottom which are T1 and T2, except different letters but the same numbers. I hope this helps you. Larry in Ohio
Mitch from Canada
>Thanks Larry,
It sounds like I'm on the right track...I'll be firing it up tomorrow.
Happy Holidays.
Mitch
Fred Davis
>Mitch,
after you have wired the switch, test it by starting up the saw and unplug it while running, then plug it back in , if the saw starts up , you need a electrician.
This test mimics a power failure while your using the saw and forgetting that it is still on , then the power coming back on reminds you , sometimes painfully , this can't happen with a properly wired Magnetic switch.
FredD
