Making an American Flat Bow or "self bow"
Matt Campbell
>I've been looking for reasonably low mess projects to keep me occupied in my apartment. I'm playing around with my scroll saw which is fairly low mess and then I discovered plans for making the American Flat Bow - a "self bow" meaning made from one continuous single piece of wood. Has anyone tried building one of these? I'm going to try my hand at it going off of the plans I've been studying but I'm curious as to whether anyone else has tried. I'm going with Red Oak for my first try because it's cheap and you can supposedly make a pretty good bow with it.
Re: Making an American Flat Bow or "self bow"
Re: Making an American Flat Bow or "self bow" *LINK*
GalenV
>I thought about it as I have an old Bear recurve take-down with the old clip design. The traditional bows would match the way I shoot, instinctive. Look at target and draw consistant. There are traditional archers around Iowa and it would probably be best to yahoo or google primative archery.
I could not find a good grain piece of Osage Orange as that was one of the best I've seen. I think I still have the link to the oak bow you may be refering to. Another good bow was a hickory and bamboo laminated bow. Elm, maple and ash can be used. Even purple heart.
When I saw the work put into one and then they found the limbs were like rubber decided to stick with my old standby.
There is a bunch of you-tube video by Bowstick Archery.
Galen
http://www.geocities.com/salampsio/oak.htm
Bill Tindall, E.TN
>If you mean a bow like the Indians shot deer with, I have a cousin in Mariana FL that makes and hunts with them. He uses Osage Orange.
traditional archery *LINK*
Bruce, a MN Galoot
>I've made several laminated longbows, and they're an awful lot of fun. It's also fun going out to the archery range with a bow that weighs roughly 20 oz and have a guy who shoots a compound pick it up and try to draw it...
Bruce
go here for some very good advice and instructions:
selfbow
which tools?
Matt Campbell
>Well, I got a good start tonight on the bow. I used my Bosch jigsaw to rough out the ends and then like the guy shows here:
http://tillertree.com/?p=44
I used my Sureform planes to begin getting the sloped shape of the belly onto one arm. I can't help thinking this would be faster using a spokeshave or a plane of some sort. I don't own either tool (I used to have a block plane but it was stolen), so I'm wondering which one would work best. I'm guessing a spokeshave would work well for roughing in and then following up with a plane to make sure everything is nice and even. Which plane would I use? Of course I could get a cheapo bandsaw like the guy in the article mentions but like him I live in an apartment and frankly I had the most fun and sense of satisfaction from the more visceral feel of using hand tools to shape the wood. Also it's a bit less messy I think than using a band saw, or at least the shavings would look more attractive spread all over the floor. So I'm looking at this spokeshave:
http://www.woodcraft.com/product.aspx?ProductID=827102&FamilyID=5130
But I'm at a loss for what type of plane would be best for this - block plane, bench plane, something else?
a bit about spokeshaves
Robin Corell in Atascadero CA
>You really shouldn't need anything other than a spokeshave. After all a spoke shave IS a plane, just one with a short sole. I do a lot of my shaping with a spokeshave, or more accurately several different shaves. The one you linked to is a low quality brutish sort of thing. Once it is trued up and sharpened properly it will do what you need to with it. For a beginner it is probably less frustrating to have a shave with blade adjusting screws. I find that a shave with a good fitting cap iron with a single thumb screw to be a more precise tool one you learn how the set the blade depth and my favorite is the little one made by xacto which sells for a whopping $6.95. The small Preston copy sold by lie nelson would be my first money-is-no-object choice.
Other than the Preston copy you will need to tune up any new shave you buy. Just follow the same steps for tuning up a plane. Flatten the sole, true up and flatten the frog, flatten the contact area of the cap iron and file the cap iron smooth so shavings don't jam in the mouth. That black painted as-cast cap iron is why that shave sells for under $30 and the bogs shave sells for over $130, well one of the reasons. The cap iron should be nice and smooth for the bottom 1/3 or so, the rest is just for show. Next the iron will need to be flattened on the back and the edge will need to be honed. When it is all done you will have a decent tool that will do all you will need to do on your bow.
Robin
Re: which tools?
>I usually start out with a drawknife before I go to a spokeshave. That way you can rough out a piece before you refine it. You may want to consider a shaving horse or shaving mule - but if you are in an apartment, I don't know where you'd store it.
The spokeshave that you gave the url for is a Stanley. It's okay, but I much prefer the Lee Valley.
Re: a bit about spokeshaves
Matt Campbell
>Thanks for the advice on the spokeshaves. I expected to have to hone the blade at the very least - they even mention it in the product description. I'm sure I can handle the rest. JL mentioned using a drawknife initially followed by the spokeshave. Do you think a flexible drawknife is any better than a rigid one, especially considering how it'll be used (bow making)? I wondered about using a regular plane like a block plane or some other type because with the longer footprint it seems like you'd be able to get a much more uniform surface than with a spokeshave. Or maybe having never used a spokeshave I'm underestimating just how well it will work for this task? Also, as I understand it, when the bow is being tillered I'll have to keep going back and removing more wood from the arms of the bow. Again, the spokeshave would be adequate to this task? If you read the how-to from the earlier link you'll see the guy made the entire bow using only the crudest tools (Surform planes, wood rasps, etc.). Also, I was looking at this:
http://www.woodcraft.com/product.aspx?ProductID=144046&FamilyID=4490
And wonder if I'm going to have to do a bunch of set up to begin with on just about any spokeshave is this worth over double the cost of the Stanley? There is also a cost issue involved. I'm not exactly flush with cash so I try to buy nice (vs. total junk), tools if not neccessarily the absolute best. Also, this is the drawknife I was looking at:
http://www.woodcraft.com/family.aspx?familyid=3616
So, drawknife and spokeshave but no plane block or bench plane?
Dan Donaldson
>Matt, ping me offline. I may have a way to help.
Re: traditional archery------WebKitFormBoundaryAA2
JimG------WebKitFormBoundaryAA2hAApkAA+UAAXL
>My son and I make one of the stickbows. We used to take it to a bow shop and shoot it in the basement. The owner was impressed, considering how simple it is to make.
>About spokeshaves and drawknives. You can do a lot of shaping and tapering and just about anything with them. The Veritas low angle spokeshave is a great one. (I've got one). But I would look at some of the other types - if you can swing them. As far as a drawknife, I'd avoid a Flexcut. They are a bit too delicate, even though they work well. You want a sturdier one.
Ping me off line and I may have some alternatives. I've got an old Stanley 151 that is in need of rehab.
GalenV
>Matt
Not sure what part of the country you are located but I think if you would search for a traditional achery club or ask at a local archery range you would find folks that would be more than willing to offer suggestions and alternatives to tools.
I went to see a group using our Izaak Walton League for a traditional archery shoot. Even though some had made bows to sale I was surprised at the willingness to tell you how to make your own.
While there I saw one guy working on a bow that his only "tool" was one large bowie knife! He did use a commercial clamp to hold it to a picnic table. I guess if you got the time you can do anything with limited tools.
Good luck on your project.
Next is drawing and tempering your own arrow shafts and plucking a bird for fletchings!
Galen
Re: which tools?
>Matt,
You don't happen to live in East TN, do you? If so, I'd be glad to give you some long pieces of white hickory and lend a spokeshave or two if you want to try them.
Matt Campbell
>I live in the Chicago area and there is at least one archery club that meets right in the city. There are also several archery stores that have shooting lanes as well. The wife and I are already planning to go check out some of the tournaments they have coming up. Neither of us has been huge into archery but it's something we'd always enjoyed when we had a chance to pick up a bow and shoot at some targets. I've hardly done that much work yet and I'm having a blast. So far this is the most fun I've had on a woodworking project in ages.
Post a progress picture from time to time.
GalenV
>A drawknife really excels in green wood. As the wood dries you will find it easier to control the cut with a spokeshave. The Stanley will do all you need. It can be tuned up to take a fine cut and if you slightly round the corners you will be able to get a very nice finish. I mentioned the xacto shave as one of my favorites and it is the one I go to when I need to refine a surface and take a shaving that is less than .005". An old 151 and a new one will likely need the same amount of work to make them into a top notch go to tool that is a pleasure to use.
In the attached pic you can get an idea of what kind of surface is possible with a shave. The leg was not sanded. This is a bit of a bait and switch as I added a 10* bevel to the front of the blade to convert it to a york pitch so I could get that surface on the curly claro walnut with out any tear out. The tiny litle shave off to the side is the xacto that I am so fond of.
Robin
Re: which tools?
Matt Campbell
>John,
Thanks for the offer but I'm up in the Chicago area. Depending on how this first bow goes and the second (the one for the wife), I'd like to try hickory after that.
Steve Kreitler
>You can get a lot more information at the Primitive Archer website linked below. I would also reccomend the "Traditional Bowyer's Bible" series, which can be found on a link at Primitive Archer. They can also be found at Half.com (do a search for "bowyer" and they will pop up). There are four books in the series (I have the first three- the fourth just came out this year), and they are truly fascinating. The article on string making alone is a real eye opener. Not to mention the chapter on making hide glue!
Half.com doesn't have them listed by volume number, but you can tell by looking at the picture of the cover- each has a bow on it, with the number of arrows laying across it designating the volume number.
Steve Kreitler
>I swear I put in the link I referenced!
www.primitivearcher.com
There! LOL
AFB construction update
Matt Campbell
>Well, I ruined my first bow. There was a slight irregularity in the grain near one tip and I hoped it wouldn't be a problem. However, a little attention with my new Pfeil spokeshave as I was further shaping the bow ended up causing that whole section to blow up out in a really large chunk. It went down far too deep into the bow at that point. There's no way I'd be able to tiller the bow effectively and it'd probably break at that point when I tried. So, I instead used the now ruined bowstave to pratice drawknife technique as well as play around with my new Veritas spokeshave and Garlik scraper set. Anyway, it looks a trip to the ol' big box home improvement place after work to sort through another 100 or so pieces of red oak looking for something suitable. I plan on getting at least 3 or 4 suitable staves this time so if I have any other mishaps I can switch to another one without having to go back out. This time around I'll take pictures as I do the work so I can post them up here for all interested parties to see.
